Install a 00' Body Kit
Old Aug 2, 2001 | 06:37 PM
MikeS's Avatar
I printed the directions from the FAQ section of the board, but it was for an 02' model. Do you still need to drill for the 00' model?
Old Aug 2, 2001 | 06:55 PM
Nate's Avatar
I believe the drilling is if you don't have mud flaps. Mud flaps, which you have to take off to install the kit, use the same holes the kit does. So, if you had mud flaps you have the holes already, otherwise you have to make them.
I think.
Old Aug 2, 2001 | 09:33 PM
BlackTL2K's Avatar
Talking
If this is for the WW body kit; you do have to drill the front and rear sections. You can use some of the tabs for the sides but you will have to cut out some slots on the WW kit to get the tabs to slide in. You probably should also use screws to mount the sides.
If this was for the OEM, then pay no attention to my message
Old Aug 3, 2001 | 09:12 PM
...and remember. You need a short (stubby) phillips screwdriver or something similar to install screws by the tire. Unless you pull the tires.
fuct
May 14, 2017 09:43 PM
InFaMouSLink
Oct 27, 2015 06:51 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
Sep 4, 2015 08:03 AM
Aug 30, 2015 02:39 PM
