inexpensive tranny fluid for the 3x3 flushing method
Old Jul 30, 2021 | 09:26 AM
mikes black ac's Avatar
02' type-s i am going to do the 3x3 method for flushing my tranny but the fluid is too expensive to waste and was wondering if there was an alternative z-1 or the superseded dw-1 on the market for a filthy tranny.could i use some cleaner in there as well like maybe seafoam trans,trans-x,or some other brand? i'd say the first drain and fill should have the cleaner/conditioner in it and then for the next 2- 5 mile drive cycles use straight fluid only.i don't know what do you think?thanks.
Old Jul 30, 2021 | 09:32 AM
Cbble's Avatar
seen many recommending Valvoline Multi-Vehicle (ATF) Full Synthetic Automatic Transmission Fluid and it's about the half the price of honda one I think
https://www.walmart.com/ip/Valvoline...-1-GA/15125768
Old Jul 30, 2021 | 09:37 AM
thanks i'll look into it.
Old Jul 30, 2021 | 09:42 AM
Saudade's Avatar
USAF Veteran
Veteran: Air Force
Walmart also carries the Castrol Transmax for imports. About $6/qt.
Old Dec 4, 2022 | 10:54 AM
3x3 flush
many thanks from so long ago..i used the castrol transmax as suggested.it did the job, i guess.i cleaned all the solenoid shifter screens,etc and changed the filter on the last run.i drove at least 100 miles in between each drain and fill to get a better clean.i'm not sure if it really made the shifting any better but at least i know that the tranny is clean and that i did everything that i could. i left the transmax in as my final fill and it's been 300 miles or so.i'm thinking of buying the honda fluid to keep in there for good.my tranny is old and has almost 300k on it.it's still going though..thanks for the info
Old Dec 4, 2022 | 11:26 AM
I did a 3X3 with the AISIN ATFDW-1 stuff in my 03 CL-S and have had no problems thus far.
It's $6.04 per quart before shipping on RA.
dc5chris209
Aug 18, 2021 01:26 PM
itsromy
Nov 29, 2012 07:41 PM
1st timer
Jun 22, 2009 09:57 PM
eddie30013
Sep 16, 2006 12:07 PM
sc354
Sep 4, 2003 10:39 AM
