indiglo gauges
indiglo gauges
I want to get indiglo gauges but i dont know about the wiring..i looked at all the threads on how to remove and instal the gauge cluster and all but i dont see any with the wires..does anyone know how to do this
You ground the negative wire, if you open the driver side fuse box, there are two screws for that purpose. For the positive, If you look behind the fuse panel there are connectors that honda made for extra accessories that are number. You want #3 because it goes on with the parking/headlights. If your indiglo gauge didn't come with a standard size female tab connector .250 width, you can go to wal mart and buy it, along with a crimper. Just plug that into the #3 connector. Hope that helps.
It's not hard to install, you just have to make sure you tape down the gauges properly or the needles will get stuck. Tape around the needle area properly. Also make sure you don't pop out the needles because they are hard to calibrate.
Here's a link to removing tghe gauge cluster
http://www.acura-tl.com/faq/faq.php#8c
Originally posted by 04AcuraTL6speed
Are they bright, or just okay...?
http://acura-tl.com/forum/showthread.php?threadid=66754
i like the reverse iniglo. but what i don't like is the bright glow on the inside of the gauges. and in between the fuel gauge. any way to get rid of that? i just want the numbers and the hash marks to light up.
songuko, where did you get your gauges from?
songoku : When installing the guages, did you remove the factory light bulbs located behind the guages? Do they show through or mess up the color at all especially when you have it in the reverse mode (ie. dark face and just illuminated numbers?
Is the EL light bright enough if i placed the indiglo behind the stock face gauges? Reason why....i don't really like the white, i rather stick with the silver, but i do like the bright blue and red. So i was planing to stick them behind the stock ones. I know that the problem is that you can't take of the niddles, I was paning just to cut out the middle part of the indigos so i can fit it behind the niddle and the motor. Think it will work?
they slide over. thats the best i can tell you. You need to just stert sliding them over and figureing out how to positioning them to get them over. Its not that hard.
http://files.subtledream.com/TL/reve...low_gauges.htm
DUDE! thanks for that link... i wasnt doing that, but i went to the link.. and DAMN!!!! they have such good info on there with good pics! Thanks again bro. that link will be soooooooo useful down the way...
..... sorry i couldnt resist the smilies
..... sorry i couldnt resist the smilieshttp://files.subtledream.com/TL/reve...low_gauges.htm
Jul 16, 2017 07:33 AM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
but while mine were out i removed the seat belt light bulb
I don't want to brake them. Thanks guys!
