I'm getting 16 mpg...
Old Oct 24, 2002 | 08:12 PM
gohan's Avatar
is that normal??...
i mean, i'm doing 95% city driving, shouldn't i be getting at least 18 or 19 mpg??....16 mpg sounds a bit low...
could there be a problem with my car??...i mean, i have a CT air filter, which i thought should help with the miles per gallon and everything else is stock....
i was thinking, could this be the result of me driving the car everyday for like 3-5 miles to school, going to class, and then a hour later, drive 3-5 miles home.....and doing this about 3-4 times a day....
could this be the cause???...
also, sometimes i see some white smoke coming out of my exhaust after i shut off my engine, which never happened b4...as well as some burning scent that i smell in the car when i drive with the climate control set over 73 degrees....weird...
could there be an exhaust problem or engine prob.??
hope someone can help.....
Old Oct 24, 2002 | 09:19 PM
fsttyms1's Avatar
its probably your driving short stop go driving is bad for milage. the smoke is probably just moisture. you really dont drive far/long enough to burn up the moisture in your exhaust and when you shut it off you see steam
Old Oct 24, 2002 | 10:33 PM
y2ks2k's Avatar
Im eaither driving 1000 miles in the far reaches of Oregon or I am driving the 8th worst traffic in the coutry every day in Portland. I get a solid 30 MPG every trip and I get 16 mpg every day in the city
Old Oct 25, 2002 | 02:49 AM
SimTypeS's Avatar
...and then there was One
Do you use SS, or leave it in D5 (or whatever)?
Old Oct 25, 2002 | 04:39 AM
samkws's Avatar
Comptech Freak
it's normal...especially when the weather gets cold and need a longer time to get the engine warm
Old Oct 25, 2002 | 07:11 AM
T Ho's Avatar
Yep.
Here's an idea- eliminate one of the trips. Stay at the library or student union. Alternately, walk or ride your bike for one of the trips. Alternately, try to put together a better (tighter) class schedule.
Just some thoughts.
Old Oct 25, 2002 | 07:14 AM
roadman's Avatar
gohan,
Based on your type of driving it sounds normal. try taking a long weekend drive for a full tank, which is 400+ miles of highway driving. For you it is like going up to the Catskills or Newport and see what your mileage is, I bet it will be close to 30mpg strictly highway.
Also keep in mind that on Nov 15 the winter gas hits our pumps and you will get less mpg (but less emissions).
Old Oct 25, 2002 | 12:22 PM
songoku's Avatar
BlingBling INSPIRE 32V
I get about 250~270 full tank gas to empty. I have never went over 300.
Old Oct 25, 2002 | 02:39 PM
fastcarz3's Avatar
400+miles on a full tank of gas?? dam i can't even manage 300 on a roadtrip on a tank. But then again flying on the NYS thurway at 3 am and doing 100mph probably isn't helping the gas mileage.
Old Oct 25, 2002 | 03:16 PM
DMan's Avatar
I've hit 400 once when I was driving cross country, but normally I get around 19-23 mixed city/highway. Most of the time my gas light usually lights when I hit 310 miles. One time I actually ran out of gas at 318. Oops:
Old Oct 26, 2002 | 12:21 AM
gohan's Avatar
sup guys...thanks for all of ur replies...
didn't have time to check the forum till now...
learned alot....and i'm getting the impression that this is normal...now i won't be taking a trip down to my dealer for a checkup....thx
SimTypeS: i leave it in D5....
yea...i think i need to cut down on some of those short trips....gas prices are getting higher.....
Old Oct 26, 2002 | 02:59 AM
power-fade's Avatar
I'M GETTING 300KM FROM FULL TO HALF...95% CITY DRIVING USING D5 ONLY
Old Oct 26, 2002 | 05:51 PM
EmuMessenger's Avatar
Sorry about your mileage. Just filled up with 16.1 gallons and 417 miles. Mixture of city and highway. I have never gotten lower than 24MPG mixed in my 2003 TLS. MY 1999 TL never got higher than 23-24MPG.
Old Oct 27, 2002 | 08:36 PM
RedLined's Avatar
I used to drive about 3500 miles a month, all highway, averaging anywhere from 28 to 33 mpg.
I now drive about 300 miles a month, all city, and have been getting about 15 mpg, mostly using the sport shift. Recently, I fractured and dislocated my left elbow playing soccer. Therefore I can't use my left arm at all to drive/steer and can't use the sport shift. And because I can only keep on hand on the wheel, I probably haven't been driving as aggressively as I usually do. Consequently, my gas mileage has gone up to close to 20 mpg.
champaned_out
May 16, 2015 06:55 PM
barewire001
Nov 27, 2014 07:42 AM
qwxilvr
Nov 16, 2014 11:45 AM
FCVadi
Oct 11, 2011 10:00 PM
raviola4
Apr 23, 2011 01:56 PM
