Ignore the Tranny TSB?
just wondering what you think if i ignore the jet kit TSB and my tranny breaks down. will it still be covered under the 100k/7yr warranty?
why would you want to igmore it? i would get it done
Originally Posted by Darkshear
A TSB is just a technical service bulliten. Its not a ticket for a new tranny. This isnt a "recall", its just a warranty extension. you gotta wait till it dies to get a new one.
ChairmanMaoSaysRTFM
you will also be without legal recourse should you be hurt since you did not listen to acuras advice.
do not put yourself in this position. the inconvenience of dropping the car off is far less than the inconvenience of being told you have to shell out 3 grand for a new trannyor god forbid having it go out in traffic and you get rear ended.
SSTS
Originally Posted by fsttyms1
why would you want to ignore it? i would get it done
am i CORRECT?
if so, i would get a new rebuilt tranny with the jet kit already included anyway.
in any case, i'm pretty dissapointed with acura in that i just don't think this is the final fix for our trannies. i have a terrible feeling many of us will be SOL after our trannies break down after passing the 7yr/100,000mi mark.
well, since my tranny already makes the whine noise (similar to going in reverse) i assume its well on its way to failure.......SOON.
am i CORRECT?
am i CORRECT?
I think you should ignore it so if the gear is bad it will fail sooner or later.When it does fail the trans locks up along with your front tires.Maybe you will be lucky enough to be on the busy freeway with a 18 wheeler tailgating you when it happens causing mass death & destruction. :blaze:
