Idle fluctuating?
Idle fluctuating?
So, today I started up my car to go to school. When i started it up i noticed it was ideling a bit high, but thought nothing of it... plus I was in a hurry. Anyway, on the way to school, I notice how reluctant the car is to stop at stop signs, and how rough the automatic downshifting is! When i put the car in park, the RPM just continuously go from 1500 RPMs to 2500 RPMS, then back down to 1500 and then back to 2500... OVER AND OVER! So I am going to lunch at school, and while im driving the Check Engine light and TCS light comes on!!!!! now im like, ok WTF! please GOD NO, NOT THE TRANNY!!!! anything but the tranny!
Anyway I took it to the shop after school. Still acting up. Any ideas?
yeah.. I had the V2 put on... it came with wires for that, but its in a diff. place than the 2000 TL.... plus the IAC has been fine for like 3 weeks now.. hmmm. hopefully this can be fixed easily!
The IAC is the Idle Air Control valve Its located on the Throttle Body. I dont know what your talking about with the V2 coming with wires for that?? Its not something that can be repaired. when it goes bad it needs to be replaced
my 2003 did the same thing once a few months ago, on my way to school...but then it never happened again after that. It hasn't done it ever again so i hope it's fine.
EDIT: I have the v2 too....no wiring for the IAC came with it at all
don't think it's supposed to and there's not really a place for wiring with a metal tube.
same exact thing happened to me. i have no clue what it means, but for me, it was the very first sign of my tranny failure(have absolutely no clue if they are related at all). 3 months later, tranny #1 gone.
good thing i just got an aftermarket warranty!
umm... with the V2, some wires came with it. Someone told me they were for the IAC, but I have no clue.... The wires dont plug into the v2, they like let the IAC know it has a new intake? i really dont know what im talking about here tho.
Originally Posted by fsttyms1
you can buy the part online for about 110 bucks and install it your self in 30 min or less
Originally Posted by -Rz-UA5
I think i need to replace my IAC too, the idle fluctuate more often than usual now. By any chance any know how much IAC roughly cost??? I got a guote for 400CDN installed.. is that a good deal??
http://www.rockauto.com/catalog/cata...IengineID=2747
the stealership over here wants $120 for it... but i took the car to my dads shop, and they like unstuck it or something... and have been driving it this weekend with no problems yet. ill prob have the part installed soon.
hey my car started doing the exact same thing today as well. and it feels slower. does anyone have a pic of this Idle Air Control Valve? Thanks.
Originally Posted by Severin
Sometimes the port just get fouled with grime and just needs to be cleaned with some intake cleaner.
The IAC has a valve that opens to let enough air bypass into the engine when idling. If it is clogged then the engine must rev in order to prevent stalling.
So just simply check if it needs to be cleaned...cleaning it helped me when I started running rich under boost.
Originally Posted by bkzjimmy
DIY...pix????
Haven't had to do it on my '00 yet. However, if you remove the rubber snorkel to the intake and look inside, you should see a passage around the butterfly which is the air passage to the IAC valve. Pick up a can of intake cleaner at your local auto store and follow the instructions. Some cleaners want the engine to be running (it will burn the cleaner), others want the engine off.
DerrickW
Nov 15, 2015 05:52 PM
