I really need help bad..
03' NBP TL-S
I really need help installing my springs.. can any that is an expert with the install post or pm me their phone number so they can help me.. i'm stuck with getting the spring out.. the fucking sway bar bolt won't come off.. i'm pretty much stuck and about to give up.. please help..
for the rear? un do the bolt on the bracket that holds the sway bar on. its alot easier to remove then just swing it out of the way
03' NBP TL-S
ok i ran into another problem.. putting in the new rear shocks.. even if I put the top hat on and bolt it down.. the spring is still loose? cuz the rear spring is shorter.. wtf am i supposed to do to align it into the right groove.. i still would appreciate someone's phone # ........... anyone??
ChairmanMaoSaysRTFM
concerning this last problem, when i did mine last year i simply had to install it and then use a hand jack to life the car up to release the tension on the spring and muscle the spring to where it needed to be.
let me know if you still need pics. i have some but i don't know if i have what you need.
have you seen this? --->
http://www.abunchofcars.com/2006/04/...stallation.php
http://www.cardomain.com/ride/184466/7
SSTS
SSTS
sl33kTL
01-24-2012 07:50 PM
