i need help
Old Sep 9, 2003 | 04:00 PM
njtls's Avatar
i need help
i juts pulled off the intake resonator and when i rev it in nutruel and parkl..the rev limter cuts in at 5 - 5.5k....is that what the rev limit is?...
Old Sep 9, 2003 | 04:14 PM
juniorbean's Avatar
Not sure... but it doesn't make sense. I would think that the rev limiter would be the same in park as it is in drive... so you should be able to rev up to redline.
Why did you pull of the intake resonator, are you installing an intake?
Old Sep 9, 2003 | 04:16 PM
njtls's Avatar
just for sound...is there anything else that would make the rev limiter go off at 5500?
Old Sep 9, 2003 | 04:39 PM
juniorbean's Avatar
Nothing I can think of off hand unless something else was accidentially disconnected. Hopefully someone else will jump in here....
Old Sep 9, 2003 | 04:59 PM
Darkshear's Avatar
l33t
The TL's rev limiter in neutral or park is 5500 RPM, dont worry, its normal.
Old Sep 9, 2003 | 08:15 PM
njtls's Avatar
whoa good..i was scared for a sec...scared and the thought of having to put the resonator back in to bring it to the dealer...
