hydrolic vs non hyrolic mounts
Subscribe
Jan 15, 2008 | 04:36 PM
i was wondering is there any real big difference between the 2 i have to replace my mounts and i found some good priced ones on ebay but there not hydrolic and acura told me that the factory mounts are hydrolic
Reply 0
Jan 15, 2008 | 05:17 PM
not only are they hydraulic oil filled motor mounts- they have a vacuum assist system!
If you are looking at solid polyurethane- those may transmit a LOT of road and engine trans feel back into the car - just my opinion
Reply 0
Jan 15, 2008 | 11:10 PM
so the factory 1s would be the only replacent then?
Reply 0
Jan 15, 2008 | 11:55 PM
The only real difference would be the non hydrolic ones might be a less comfy ride.
Reply 0
Jan 16, 2008 | 12:56 AM
IMO, the factory ones are crap. I say they are crap because they break fairly easily, especially in a modified TLS/CLS. I had my first mount (I think it was the front one, with only headers) go bad at 50k and now at 70k, the mounts are shot. Despite being 18, I drive pretty conservative.
You could always pick up a set of Innovative Motor Mounts from Excelerate (in Black Market). They are advertised to be more comfortable than stock and have a lifetime warranty. That's what I did.
If you want to wait, I can report back about the difference in ride once I get them in and installed.
Reply 0
Jan 16, 2008 | 02:16 AM
you cant buy the mounts at zone- its dealer or the special aftermarket ones
As I had said- the poly filled bushing will transmit more feedback to the car than the vac-oil setup.
Yes they break- usually around 50-70-90k miles regardless of how you drive.
That doesnt make it a suck part- just doing its job takes a lot of effort
You try holding on during vtec!
Reply 0
Jan 16, 2008 | 02:27 AM
Quote: The only real difference would be the non hydrolic ones might be a less comfy ride.
ok ill wait until you get yours done to see how they ride either way these are the ones im looking at http://cgi.ebay.ca/98-00-02-Honda-Ac...QQcmdZViewItem
dirt cheap for all so im worried never shopped off ebay
no matter how i look at it all my mounts are shot so they cant be any worst than thr ride now
Reply 0
Jan 16, 2008 | 07:20 AM
I just replaced the front and side mount. OEM Acura parts cost $130 shipped to me from an Acura Dealership in Georgia. The rear mount seldom goes bad on our cars and mine was fine.
Reply 0
Jan 17, 2008 | 07:09 PM
Quote: I just replaced the front and side mount. OEM Acura parts cost $130 shipped to me from an Acura Dealership in Georgia. The rear mount seldom goes bad on our cars and mine was fine.
really are you serious ?
thats sounds like a good price are the parts used ....?
can you give me the link to that dealer please
Reply 0
Jan 17, 2008 | 08:37 PM
Cheapest OEM Acura parts site I have found -- www.acuraautomotiveparts.org
Reply 0
Jan 17, 2008 | 08:49 PM
Quote: Cheapest OEM Acura parts site I have found -- www.acuraautomotiveparts.org
what parts do i need to order like the part number for the mounts that need to be replaced i dont know wich 1s are broken i know the front 1 is for sure but i dont know about the other 1s or how to check them
Reply 0
Jan 17, 2008 | 09:55 PM
http://www.acuraautomotiveparts.org/...s=&view=normal
EDIT: That is for a 99, but I think all the TL-P's use the same mounts.
Reply 0
Jan 18, 2008 | 06:06 AM
[QUOTE=KSuchdeve]http://www.acuraautomotiveparts.org/...s=&view=normal
EDIT: That is for a 99, but I think all the TL-P's use the same mounts.[/QUOTE
Yes that's the site I used in Georgia. Plug in your cars info. on the site. Year, model etc. and click on Engine Mount. You will find them there. I ordered mine online. Shipping was cheap and parts were about 25% less than the stealership here in the Asheville NC area.
Reply 0
Jan 18, 2008 | 08:37 AM
Quote: EDIT: That is for a 99, but I think all the TL-P's use the same mounts.
99 TL front mount is different
99TL: 50810-S87-A81
00-03TL: 50800-S0K-A81
I installed the 00-03 TL front mount on my 99 and it worked fine.
Reply 0
Jan 18, 2008 | 11:39 AM
stupid acura...gave me a brand new tranny but, didnt bother to replace the mounts! im in need of new ones, i think.
Reply 0
Jan 18, 2008 | 04:50 PM
Quote: 99 TL front mount is different
99TL: 50810-S87-A81
That's why I put I think. Thanks for clearing that up for us .
Reply 0
Jan 23, 2008 | 09:53 AM
Here is another OEM parts dealer:
http://www.acuraoemparts.com/delray/jsp/home.jsp
Reply 0
Jan 23, 2008 | 10:11 AM
03aspec
The dealer would have inspected them while trans is out- and usually suggest replacement based on leakage found while under the car.
Since the parts are just over 100, the labor is the killer UNLESS trans is already removed
If you just got a trans and its acting funny, go back to the dealer.
If it does need mounts- they should charge you the labor for doing it with trans removed already- thats 3/10s of 1 hour not 3 hours!
Reply 0
Jan 23, 2008 | 11:25 PM
I should be getting mine in the mail on friday. I will hopefully get them installed this weekend and I'll report back on how they are compared to the POS factory ones.
Reply 0
Jan 23, 2008 | 11:48 PM
My Innovative ones are on the way too.
Reply 0
Jan 28, 2008 | 12:41 AM
I received mine, but I haven't yet had time to get them installed. School first. There are a couple of reviews in the BM about them though.
Reply 0
Jan 29, 2008 | 10:01 PM
The vibrations at idle are increased, but not excessive.
The ride is more secure, the car feels very planted to the ground at WOT. I'd definitely get these again!
Reply 0
Jan 29, 2008 | 10:10 PM
Nice mine are on the way and getting installed within the next few weeks.
Reply 0
Apr 10, 2008 | 11:32 AM
So vibration is increased. Is it clearly noticeable, as in takes away from the comfort the car initially had?
Reply 0
Apr 10, 2008 | 12:38 PM
Quote: So vibration is increased. Is it clearly noticeable, as in takes away from the comfort the car initially had?
Yes it is noticeable and it does take a way from some of the comfort at idle, but I was stuck in stop and go traffic for two hours and it was plenty bareable. At highway speeds, no difference from stock.
IMPORTANT: there was an issue with the side mount, Excelerate and Innovative are sending everyone a new redesigned side mount. If you have time, ask me after I put that new one in to see if anything changed.
Reply 0
Subscribe
