Huge Electrical Problem in my TL
Sorry to make a new thread guys, but i searched and didnt really get what i was looking for based on my problem. Heres what happened: i was messing around with the auto dim mirror and unplugging it as well as the over head lights. I accidently plugged the light power into where the auto dim plug goes underneath the head liner and it made a funny noise. I took it out quickly and started the car but none of my gauges work. The power windows and sunroof also dont work. When i put the car into D it slams into it and is really violent and not smooth at all. Could this all be a transmission problem? Did i short out the electric work? Whats going on here? any help would be greatly appreciated.
i actually changed the fuse for the passenger window and nothing changed. Is there a fuse for the instrument pannel (gauges). Also the battery light is showing up when the key is in the second position which is the only light on the dash, so ill probably have it scanned tommorw. How can i tell if a fuse is blown?
Prick of the month
If a fuse is blown the metal filament in the center of the plastic will be broken, very easy to tell. Just make sure you use the same rated fuse to replace them if they are blown, i.e. 7.5 amp for a 7.5 amp.
Unplugging it shouldnt have caused a noise. Did you pill on the wire? Did it sound like something electrical arching?
It was when I plugged the light power into where the auto dim miirror goes, that it made a noise. And ever since then it all stopped working. My dad took it to his mechanic today so im just hoping its nothing too serious.
Is the way I described the transmission shifting hard a symptom of a tranny failure? If so ill sell it sooon lol, or swap in the 6 speed that people seem to be doing lately
did it go into gear like that before you had this electrical issue?
I've got a 3G manual, so I'm not sure the circuit diagram applies to a 2G, but on the 3G the auto dim mirror is connected to the MICU (Multiplex Integrated Control Unit) on a TL with A/T. This signals the mirror not to dim if you're in reverse.
Anyway, the MICU is also connected to the PCM (Powertrain Control Module) which is also connected to the Gauge Control Module.
So it's not too hard to believe that by connecting power to the auto dim connecter, current could have been sent to all of these components.
I'd check fuses first, but I'm guessing it's no coincidence that your having trouble with the transmission and the gauges don't work. I can't offer an explaination for the power windows.
Good luck - I hope it's just a fuse.
Well guys thanks for all your help, it turned out to be the fuses. We replaced each blown fuse and everything went back to working order. The transmission isnt as violent but were replacing the passenger ball joint which should reduce some vibrations and roughness from the tranny shaking i guess. Now that everything is okay, i noticed that the car does not pick up like it used to. This could just be in my head, but it doesnt really pull as hard as it used to and vtec isnt as loud. Any ideas as to what it could be or is it just in my head?
Originally Posted by KSuchdeve
I dunno speaking of the vtec problems, after I got my new ECU, my vtec seems to kick in right under 4K RPMS instead of higher when it used to.
Prick of the month
I'm glad that the problem was just with the fuses!
While it can be a hassle, it's best to disconnect the car's battery whenever you're hooking up any electrical items or rewiring anything. It doesn't take much of a voltage spike or short to fry a lot of expensive electronics.
Originally Posted by t0ast
Try disconnecting the battery for maybe 30 mins. It'll reset the ECU (as well as the radio so make sure you have the radio code).
Burned it out trying to do the door handle LED mod. Tapped into the wrong wires so I sent power to the wrong part of ECU and fried it.
brandnewcolony
09-12-2015 10:39 AM
