angle-ing my HID'S
Old Jan 9, 2006 | 06:56 PM
Blazin_TL's Avatar
Registered User
angle-ing my HID'S
i installed a pair of 6000k's today and i realized that one light beams a lil higher than the other.. how do i level out that light to be more even with the other one?
yeah i did a search and couldn't find much
thanks d00ds
Old Jan 9, 2006 | 07:17 PM
RickRoush03's Avatar
RickRoush03
i need this info also b/c mine sit a tad low, also, can someone take a pic and point out the screw to adjust as i played around with the ones i saw to no aval.
Old Jan 9, 2006 | 07:45 PM
fsttyms1's Avatar
If you pop the hood you will see above teh headlight on the black trim piece there is a arrow with up and down. Below that on the back of the headlight is an adjustment screw. At night (easiest to see) park facing a wall so you can see the light pattern, and start adjusting. I forgot what size bolt it is but a small 1/4 inch wratchet will adgust them
Old Jan 9, 2006 | 08:49 PM
Da_iLLeZt_TL973's Avatar
Future JDM Whore
i believe its a 10mm bolt
Old Jan 9, 2006 | 09:00 PM
TL_Fo_Life's Avatar
My "P" SpAnKs YouR "S"
yup its a 10. It'll adjust up and down. left to right is handled by a small grey wheel that can be turned by hand. just stand in front of the headlight and look down at it, you'll figure it out.
Old Jan 9, 2006 | 11:21 PM
Blazin_TL's Avatar
Registered User
alright thanks guys!
Old Jan 10, 2006 | 03:24 PM
bkzjimmy's Avatar
NiGhT rIdEr
thats on the 02-03........... on the 99-01 its a phillips head screwdriver.
Old Jan 10, 2006 | 03:55 PM
fsttyms1's Avatar
My 2000 used a 10mm socket
Old Jan 10, 2006 | 04:07 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
Kris you're not going to mention the obvious in this thread?!
The driver's side headlight is purposely aimed lower than the passenger one to reduce glare for oncoming traffic. It's best that you leave this slight difference. It creates a "step" look on the road, and all car headlights are like this now - the beam patterns are designed for it. By making them level, it will make it seem that one is brighter than the other. This is from my experience.
You should only adjust them if they are too high or too low, or drastically uneven.
Old Jan 10, 2006 | 04:16 PM
bkzjimmy's Avatar
NiGhT rIdEr
then both of mine are broke on my 2000
Old Jan 10, 2006 | 04:56 PM
TL_Fo_Life's Avatar
I want my headlights even. If anyone should be concerned about glare and oncoming traffic, it should be that idiot with the lifted SUV.
Old Jan 10, 2006 | 05:01 PM
fsttyms1's Avatar
Nope, cause i adjusted mine to be a littel higher and even (helps me see the pitch black north woods roads better)
What do you mean by that?
Old Jan 10, 2006 | 05:52 PM
bkzjimmy's Avatar
NiGhT rIdEr
i'll take a pic tomorrow
Old Jan 10, 2006 | 09:58 PM
RickRoush03
thanks guys, i thought i was using the right nut, i was just turning it the wrong way, put it up against a white wall, could see the beam moving up when i gave it another attempt!! that left one though is a bitch to get to !!
Old Jan 11, 2006 | 02:23 PM
bkzjimmy's Avatar
NiGhT rIdEr
this is what i was talking about....what am i doing wrong??
Old Jan 12, 2006 | 07:22 PM
bkzjimmy's Avatar
NiGhT rIdEr
someone please help me ......my light points right to the ground....
Old Jan 12, 2006 | 07:28 PM
fsttyms1's Avatar
Huh. thats where mine has a 10 mm bolt. well thats the adjustment bolt/screw. Use teh info above and adjust with a screw driver i guess
Old Jan 12, 2006 | 07:43 PM
bkzjimmy's Avatar
NiGhT rIdEr
thanx for the info, i thought i was turning the wrong thing.
Old Jan 13, 2006 | 11:09 PM
bkzjimmy's Avatar
NiGhT rIdEr
WELL, i keep turning and it doesnt go high enough ( points almost straight down!) it will go down further tho but not high enough....the bad thing is that its the passenger side light that has this problem!
so, my Q is.....do i need new housing or is there a way to fix it???
Old Jan 13, 2006 | 11:21 PM
Deity711's Avatar
Yes it is!
When I adjusted mine, it took a lot of turning of that nut to notice any difference. It's adjusts them in the smallest incriments.
Old Jan 13, 2006 | 11:53 PM
bkzjimmy's Avatar
NiGhT rIdEr
when i turn it to point it down, it moves pretty quickly....then when i turn it to put it back up, it moves pretty quickly but it just stops at one point that not high enough.
Old Jan 14, 2006 | 12:07 AM
Blazin_TL's Avatar
Registered User
was your light always down like that? or was there somthing that caused it to move downwards?
Old Jan 14, 2006 | 12:28 AM
bkzjimmy's Avatar
NiGhT rIdEr
my lights were stolen and the retard that installed the new ones didnt know what he was doing......and no im not gunna go back to him.
Old Jan 23, 2006 | 08:59 AM
bkzjimmy's Avatar
NiGhT rIdEr
this is the problem, look at the right side. theres like no light. theheadlight points straight down and it wont go any higher
Old Jan 23, 2006 | 09:39 AM
fsttyms1's Avatar
looks like they arent installed properly? you Are probably going to have to figure out why you cant raise it up any higher. Does the head light housing itself look like its sitting the way it should (IE fitment) maybe its not bolted in corectly?
Old Jan 23, 2006 | 12:26 PM
bkzjimmy's Avatar
NiGhT rIdEr
yea, its in right.....i did even try to lean the whole housing back.
heres a pic....it looks ok.
what would i have to do?? buy a new housing or is there a way to fix it??
pleeeeeez help me
Old Jan 23, 2006 | 12:31 PM
fsttyms1's Avatar
?? dont know what to say? its possible that what ever the bolt turns into to raise and lower is striped out? i would take it out and inspect every thing and see if you can cind a solution to it other than having to buy a new ones
Old Jan 23, 2006 | 12:34 PM
bkzjimmy's Avatar
NiGhT rIdEr
thanx......im just gunna have to wait till the weather get a lil better.
Old Jan 23, 2006 | 12:37 PM
fsttyms1's Avatar
try seeing if you can remove the adjusting bolt
Old Feb 17, 2006 | 09:36 PM
jpadilla's Avatar
when it start pointing down? did you pull out your bulb? I bet you installed the bulb upside down ... the long metal rod should be facing down.
Old Sep 27, 2007 | 12:21 AM
Lo Pan's Avatar
B A N N E D
sorry for double posting, but i was redirected to this thread and i thot this would be a better thread to resurrect.
so only the 02-03 adjust via a 10 mm and the 99-01 uses a philips?
as i look straight down, what jumps at me is a silver 10MM bolt (2001)
which way should i turn it? i tried both ways and it doesnt seem to budge, is it something that has to be turned a lot?
Jul 16, 2017 07:33 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
