How would this work as far as navi conversion...
...is concerned. I can get this CHEAP, so how would one go about sending a signal from a DVD player, to this unit, and then getting a video signal to the FACTORY nav screen? Haven't done any messing around with the dvd rom unit. so I'm not sure if it has some sort of video in signal where I can take advantage of this switcher.
http://www.pioneerelectronics.com/pn..._33692,00.html
Link doesn't work..
Anyways, if you want Nav conversion, there's simple solution.
http://www.avelectronic.com/products.htm
This doesn't require any wire cutting. It's direct plug & play for our TL.
I've seen that product and I'm thinking this is the cheaper solution.
Ok, my question is how can it be installed with our navigation control module?
I have pioneer GEX modified to hooked up with R,G,B, comp sinc video signal of screen to get the video.
concerning the units that have worked - avcrgb1 and gex7000tv - these both have that rectangular connector for composite signals. your unit does not (ie, uses rca connections for output) so i assume it won't work or will be an arduous process to find out.
Ol'Dave
Sep 5, 2020 02:56 PM
Vejey Gandier
Sep 12, 2015 08:59 PM
yahelou
Sep 6, 2015 09:12 PM
SUPRMN84
Sep 2, 2015 11:50 PM
