How to Remove Third Brake Light Housing
Take out the rear seats (bottom and back), remove the two bulbs from the housing (you can get to them from the trunk), then sit in the back seat facing backwards and push up on the front of the housing and it should snap up and out.
wham bam thank you ma'am
i dont think u have the remove the rear seats. i just put a screwdriver (flat head) in between the rear sub cover and the carpet like plates on either side and turn the screwdriver 90degree and just pull the whole sub cover off (dont forget to undo the 3rd brake light bulbs)
^I think thats what your talking about
1. I remove the seat back but NOT the seat bottom.
2. You do not need to remove the bulbs. That's just asking for them to break. Simply open the trunk and unplug the 2 cables going to the bulbs. They are just plastic prongs -- squeeze and pull, lol.
3. Lift/pop up the front of the housing and pull towards you. It comes right out. Do the opposite for installation.
*If you have window tint be VERY careful when you remove and re-install. The housing will most likely hit the rear window and you can very easily scratch the tint.
Removing the seat is not necessary.
Alright, now that I have taken it out, I can offer my suggestion for the best way to remove it:
Step 1) Unhook the two bulbs
Step 2) Pull off the cover to the car seat bracket (just open the lid and pull it off)
Step 3) Unbolt the bracket (it's a 12mm)
Step 4) Stick a screwdriver under the panel as shown above and turn (do it on the left and right
Step 5) Lift up the front of the panel and pull towards you
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
