How much will it cost to replace ignition switch
Old Dec 9, 2006 | 07:04 PM
03c0upe's Avatar
1999 tl
How much will it cost me if i just take it to a reg mechanic? parts n labor
Old Dec 9, 2006 | 08:34 PM
Blazin_TL's Avatar
Registered User
why dont u get some estimates?
Old Dec 9, 2006 | 08:41 PM
03c0upe's Avatar
1999 tl
its a long story..i bought my car used last week..and my car woulndt start at work so i got it towed to his mechanic..he said he will cover only upto 200$ after that he wants to split the cost 50:50 so i would like to know....i called acura they said the switch is 300ish cdn..is that wat i need or just the electricial part which is 90$???
Old Dec 9, 2006 | 09:03 PM
fsttyms1's Avatar
most likely its the immobilizer. You can tell by the key symbol in your inst cluster.
Old Dec 9, 2006 | 09:04 PM
fsttyms1's Avatar
by not start, did it crank and crank and not fire, or did it just not crank either?
Old Dec 10, 2006 | 01:31 AM
03c0upe's Avatar
1999 tl
i tried to start it..seems like it was goin to start but died..then i turned the key and held it there and it started upp...so i guess that eliminates the immobilzer problem?
ps: this is my orignal post https://acurazine.com/forums/ramblings-12/amish-city-wtf-149299/
Old Dec 10, 2006 | 09:00 AM
fsttyms1's Avatar
Well as it turns out you have a 99 and they had a ignition switch problem. Contact your dealer. They may replace it for free
Old Dec 10, 2006 | 02:36 PM
03c0upe's Avatar
1999 tl
they said im not coverd or nor is there any recall with my Vin..i just want to know what gets replaced? The whole switch or not..there is 2 parts
Old Dec 10, 2006 | 09:08 PM
fsttyms1's Avatar
register with owners link to see for sure. and if it is the switch thats all you need.
Old Dec 10, 2006 | 09:29 PM
Darkshear's Avatar
l33t
If I recall correctly, the "recall" on the switch was a result of symptoms such as shutting off randomly, not difficulty to start. Correct me if I'm wrong?
If I'm not wrong on that, there could be a different issue.
And I also thought every single '99 was covered in that... Mine was manufactured in late March of 1999, twords the end of the model year, and I had the problem and the recall as well...
Old Dec 11, 2006 | 08:16 AM
NSXNEXT's Avatar
Ignition switch should run you $50 - $60 and I can't imagine then charging more than and hour to install.
You could easily do it yourself
1) Disconnect battery
2) Remove plastic cover around steering column (2 screws on the underside of cover)
3) Remove 2 screws holding ignition switch in
4) Trace the wiring harness back to the fuse box
5) Disonnect wiring harness
6) Connect new ignition switch
Part #8
Old Dec 11, 2006 | 10:34 AM
fsttyms1's Avatar
In one of his other ignition threads he said it shut off while driving
Old Dec 11, 2006 | 02:48 PM
03c0upe's Avatar
1999 tl
Part #8
50-60$? are you sure acura gave me 2 prices..300 for the whole switch..and 80 for the harness or something...
Old Dec 11, 2006 | 03:02 PM
Bob_F's Avatar
Back when I was trying to diagnose my 1999 TL's stalling problems I bought a replacement ignition switch for less than $60 form an Acura dealer's online sales dept. I have no idea what the $300 part might be.
If you can, post the Acura part numbers here and someone might be able to help out.
Bob
Old Dec 11, 2006 | 03:09 PM
03c0upe's Avatar
1999 tl
ok i found out the 300$ part includes the new keyss....so i dont need that correct?
Old Dec 11, 2006 | 05:56 PM
fsttyms1's Avatar
http://www.acuraautomotiveparts.org/...catdisplay.jsp
Old Dec 12, 2006 | 01:13 PM
03c0upe's Avatar
1999 tl
ok i got the car back from the mechanic...he said changed the immboilzer chip wtf is that?
Old Dec 12, 2006 | 01:43 PM
fsttyms1's Avatar
Thats the security device that wont let the car start with out the right key.
Old Dec 12, 2006 | 02:03 PM
03c0upe's Avatar
1999 tl
ok but my car did start if i held it in the start postion. before i got it fixed..wouldnt u have reprogram your keys if i got a new immoblizer chip? because my both my old keys work right now..anyways i think i got scammed
mada51589
Jan 9, 2025 04:40 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
Skirmich
Sep 15, 2015 06:41 PM
Soul_Deamon
Sep 7, 2015 04:25 PM
