How Many Thermostats Does it Take to...?
Old 07-28-2011, 01:34 PM
  #81
alexh1266's Avatar
Originally Posted by 01tl4tl
you spoke directly with the service MANAGER?
not a commission pay based service WRITER
if thats your car in avatar= its crying for a 6 speed
The dealer's deal is pretty much that if I only pay to change the trans and dont change the other recommend parts along with it such as the PCM and fuel pressure regulator, then they won't honor the 3/36 warranty that goes along with the trans change. I'm not interested in paying 4-5k for a new auto trans when i can probably get a 6spd swap for around the same price and keep. I do about 90% highway driving and 10% city driving. So its not a big deal.
And yes thats my car in the avatar. here's a pict thread https://acurazine.com/forums/2g-tl-photograph-gallery-99/no-fins-attached-811513/
Old 07-28-2011, 01:46 PM
  #82
Boomer SOONER
ou sig's Avatar
hey all been a while since I posted. every time I come back to the site I am so amazed how great of a site this is...anyway to continue the overheating issue
wanted to bounce my situation off you all to basically tell me what I already think I know but need someone to tell me for sure.
1999TL 180000 miles
I got the TB/water pump, coolent flush done around 115000 miles so about 5 years ago. 1) The past couple summers when it is 105+ (like the past 20 dang days here!) my car will get hot at the stoplight with the AC on. when it goes past 1/2 I just turn the AC off and blow the regular fan and it will go back down - quickly when I start driving.
2) when I open the hood the driver side fan is NOT on, while the passenger side always is. when the engine is cool and running, neither fan is on until I turn the AC on then the passenger one is on.
so considering the age I assume
1) I need to put in a new radiator
2) replace the temp sensor maybe? sorry I have not diagnosed the driver fan for an electrical issue - is that easy to do? is spins freely when I spin by hand but wont fire up
I want to fix this ASAP because I am sick of the cat and mouse game ever day when I drive home to keep her from getting too hot...I have already replaced the thermostat and hoses in the past
Old 07-28-2011, 02:15 PM
  #83
alexh1266's Avatar
This would be the problem to look at. I recommend changing the fan temp sensor. The driver side fan should work on it's own. And if the pass side is on without the driver side on then that's a problem. If they are both working with the A/C unit on then I doubt its a fan motor problem.
Get that driver side fan running right and it will most likely fix your problem.
Old 07-28-2011, 02:56 PM
  #84
Boomer SOONER
ou sig's Avatar
ok thanks - I will look into that 1st. looks like a cheap part at least
Old 07-29-2011, 08:06 AM
  #85
Boomer SOONER
ou sig's Avatar
well I pulled out the volt meter and found that the drivers fan is getting power so it must be dead. I will be ordering a new fan assembly
Old 07-29-2011, 10:55 AM
  #86
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
does the fan sensor work??
if the fan turns freely by hand its usually ok, did you jumper power to the fan power to test?
lets make sure you buy parts that will help
power and power when needed may not be the same
Old 07-29-2011, 10:56 AM
  #87
01tl4tl's Avatar
I'd say well over 70% of reports on here end up being the fan temp sensor-
located pass lower corner of rad on 00+ years, screws in
and near thermostat on 99
Old 07-29-2011, 12:41 PM
  #88
Boomer SOONER
ou sig's Avatar
well I just assumed it was the fan because when I got home yesterday I kept the engine on and when I swapped the connectors on the top of the fans the drivers side connector turned the passenger fan on again. And I checked that both had full power at the connector. so that led me to believe that the temp sensor was working and telling the driver fan to turn on but it was not?
Old 07-29-2011, 02:29 PM
  #89
Boomer SOONER
ou sig's Avatar
guys I unless I am all wrong I think it is the fan, I was going to order one from rockauto
if there is something I am missing let me know please
Old 07-29-2011, 05:38 PM
  #90
01tl4tl's Avatar
ok you win,
if power from driver fan operates pass fan,,but not its own fan
= dead fan
Old 07-30-2011, 01:19 PM
  #91
alexh1266's Avatar
Old 08-03-2011, 07:24 AM
  #92
Boomer SOONER
ou sig's Avatar
wanted to update - yes it was the fan. I got the new one yesterday from rockauto and it works perfectly. I put it in at 8:00 last night when it was still 104 outside here in the Dallas area...
I did notice how VERY dirty the back of the radiator was so I cleaned it out real good from the front and back and pulled the other fan out so I could clean behind that one. I also replaced the radiator cap that was all jacked up.
thanks again for everyones replys
Old 08-03-2011, 09:49 AM
  #93
01tl4tl's Avatar
so it was 2 part prob--bad rad cap wont pressurize the system
and bad fan wont pull air thru rad to remove that excess heat!
Old 08-03-2011, 10:43 AM
  #94
Boomer SOONER
ou sig's Avatar
ya that and radiator was really dirty - can't believe I didnt take care of this 3 years ago when I 1st noticed the issue...I guess it has never been this dang hot in Dallas for it to be such a daily problem
Old 08-03-2011, 01:08 PM
  #95
alexh1266's Avatar
3 YEARS!
Cooling Problems Are No Joke!
Glad you got it fixed finally though
Old 08-03-2011, 02:22 PM
  #96
Boomer SOONER
ou sig's Avatar
ya I have had this car for nearly 10 years so I feel like we "know" each other. So I was always good enough to keep it from getting too hot but this summer is so hot I could not do it anymore and just not a good situation if the wife ever had to drive it.
it is very random because I am usually very anal about maintenance and fixing things. Guess time flys when you have a 2 year old at home after work!
Acura604
10-07-2015 06:08 PM
2Quik
09-21-2015 08:51 AM
Bahamanurse1
09-10-2015 10:05 PM
NSolace
09-03-2015 08:02 PM
dallison
03-02-2005 04:21 PM
Quick Reply: How Many Thermostats Does it Take to...?
