How to make a DTC appear?
Old Dec 13, 2008 | 11:59 PM
newperson's Avatar
There's no Acura in
Cool How to make a DTC appear?
Anyone know a simple way on the 2G TL to generate a harmless Diagnostic Trouble Code? Like if you pull this fuse, that code gets thrown, but the fact that the code is present isn't life-threatening.
And also, how 'bout making your CEL come on? This one may not be so harmless.
For example, say I pulled a spark plug; would a DTC get thrown and/or CEL illuminate? Except I don't know if having an open spark plug hole is harmless to your engine or not (wouldn't it throw off the vacuum?).
Any ideas? Before you ask, I'm developing software.
Old Dec 14, 2008 | 01:42 AM
phee's Avatar
I got the Shifts
easiest way to get the CEL to turn on is to start the car with no throttle body on.
Old Dec 14, 2008 | 01:52 AM
abptltypes02's Avatar
Scooby doobie crusin
lol reminds me of my old si i had i was cleanin out the tb and i took off the intake and o2 sensor drove around for a lil while. vtec was pretty loud with a open throttle body but sure enough CEL lol
Old Dec 14, 2008 | 03:28 AM
dsickles's Avatar
unplugging a sensor might work, not sure about how well it will run though
Old Dec 14, 2008 | 08:22 AM
newperson's Avatar
There's no Acura in
I don't plan on driving it with the CEL on. I just want it to come on while parked, then I can do my testing my the software I'm developing. Then "undo" what I did to make the CEL illuminate and call it a day.
I just want something that's quick to do and won't F up my engine...which is why I don't want to experiment and am relying on the pros on AZine! For example, if all I had to do was unplug this sensor and not even have to crank, that's optimal.
Old Dec 14, 2008 | 08:28 AM
fsttyms1's Avatar
Ah no, DO NOT do that, Dont take off the TB and try to start the car. There will be Nothing to keep the motor from redlining and it will not be good for it. Probably get some flames and backfire too.
Just unplug a sensor like the TPS or IACV, O2 sensor ETC... And start the car.
Old Dec 14, 2008 | 08:36 AM
newperson's Avatar
There's no Acura in
Lol, I figured that about the start-with-no-TB-on. Wouldn't the engine be sucking in as much (unfiltered!) air as possible? Thanks for the confirmation!
I'll try the TPS & IACV, seems like the easiest to do.
Old Dec 14, 2008 | 08:38 AM
fsttyms1's Avatar
Yes, there would be no way to regulate the amount of air coming into the engine and it will essentially go to max rpm
You could also unplug a coilpack too.
Old Dec 14, 2008 | 08:42 AM
Rajca's Avatar
wham bam thank you ma'am
look in the fuse boxes and take out a fuse that is semi important. my 02cents
Old Dec 14, 2008 | 08:43 AM
fsttyms1's Avatar
Easier to pop the hood and unplug a sensor.
Old Dec 14, 2008 | 11:20 AM
CJITTY's Avatar
Ackniculous One
leaving your gas cap off will throw a CEL
Old Dec 14, 2008 | 01:56 PM
newperson's Avatar
There's no Acura in
^ Good idea...makes me remember the time I left my gas cap on top of my old car!
Old Dec 15, 2008 | 06:43 AM
totaledTL's Avatar
Now that's easy....... leave that TB alone.....
Old Dec 15, 2008 | 10:36 AM
phee's Avatar
I got the Shifts
my CEL didnt come on when i left my gas cap off
Old Dec 15, 2008 | 12:19 PM
fsttyms1's Avatar
And a lot of time it wont. Unplugging a sensor is the best way to get it to trigger
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
pistacio
Sep 26, 2015 09:45 AM
