how long does the battery last?
Old Dec 23, 2006 | 01:55 AM
wasup1357's Avatar
00 TL
hi i left my 00 tl at college while flying home. I didnt disconnect the battery and im wondering if i can still start my car after a month of not driving it
Old Dec 23, 2006 | 02:35 AM
Leo Type-S's Avatar
03' NBP TL-S
i hope it's not cold where u are. not the greatest of ideas, but i don't know for sure. i'm sure someone could answer this. try searching also.
Old Dec 23, 2006 | 02:37 PM
jason0617's Avatar
Don't worry about it. Come back after a month, and try it. If it starts, then this was a pointless thread. If it doesn't start, make a new friend who has jumper cables in his or her car, and get a jump start.
Just like that, your car will be running.
Glad I could help you out.
Old Dec 23, 2006 | 02:40 PM
fsttyms1's Avatar
After a full month it will most likely be dead or really low. Especially if its and original 00 battery
Old Dec 23, 2006 | 09:36 PM
01tl4tl's Avatar
My original 2001 factory battery gave out a few months ago, and you will find that with the increased electrical demands of winter- your battery may need replacing soon.
SEE Radio code threads before disconnectiong battery.'
I would always advise that a slow charge from a battery charger be put into the battery rather than a surge charge from jumping, and full alternator output into a dead battery.
Old Dec 23, 2006 | 10:05 PM
RevinV12s's Avatar
Fallen
Well, If you havent changed your battery since 00, then yes it WILL die after a month. I have not changed the battery since 03 and left the car at home while I was staying at school for a month. The result: It wont even pop the trunk after a month
Since I had my jump starter cable in the trunk, I had to buy a new one to start my car..
Took it to the dealer, they changed the battery for me....
Old Dec 23, 2006 | 10:29 PM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
batterys last exactly 1825 days.
Old Dec 23, 2006 | 10:45 PM
acutee's Avatar
the oem battery will last roughly about 3 years. if you have an oem battery, it surely will die after a month.
Old Dec 23, 2006 | 10:47 PM
Trackruner228's Avatar
Uh oh mine lasted 1824 days. I think im entitled to about 10K refund from acura.
Old Dec 23, 2006 | 10:49 PM
acutee's Avatar
Is your car still under warranty? I believe your battery is also covered under 4yrs/50k.
Old Dec 23, 2006 | 10:51 PM
nguyen's Avatar
perfect excuse to get a yellow top!!!!!
Old Dec 23, 2006 | 11:41 PM
actually I was just joking around i wasnt serious sorry haha. I bought the car used and its a 00 so its out of the warranty but its diffenently not the original battery.
Old Dec 23, 2006 | 11:56 PM
SwampGas's Avatar
/etc/car
2001 purchased in october of 2000....original battery. Slooooow cranking in the cold.
Might be time for a preemptive battery swap before I get stranded in the middle of nowhere.
Old Dec 24, 2006 | 01:08 AM
hl08015's Avatar
5th Gear
I have a 99 and a 03 tl's. both purchased brand new, i use the 99 for the winter time on the original battery. she fires right up on a cold morning. on the 03 after 6 months of storage she fires up just fine too! both cars have original oem batteries.
Old Dec 24, 2006 | 01:16 AM
Rpappi's Avatar
6 years on my still running strong.
Old Dec 24, 2006 | 01:42 AM
Leo Type-S's Avatar
03' NBP TL-S
^ OEM?? wow..
i actually want mine to run out. so i can buy a red top.
Old Dec 24, 2006 | 03:06 AM
Billy Sacco's Avatar
Kilos of yayo in
One thing to keep in mind also is that regular lead acid batteries won't survive very long after being discharged a few times. The sealed batteries (optima, stinger, odyssey) are supposed to be a lot better about this. I have an odyssey battery and was able to charge it back from it reading 4 volts and it has been running strong for about a year now since then. Lead acid batteries that are discharged down to a certain point usually can't be charged back up. A sealed battery is not a bad investment IMO especially if you live in sever weather and or have a big stereo system that could drain your battery.
Old Dec 24, 2006 | 03:21 AM
bgl2687's Avatar
anyone know why I always have buildup on the clamps?
Old Dec 24, 2006 | 03:37 AM
Kilos of yayo in
Do you have any high current accessories like an audio setup or something? I started getting alot of buildup after I installed my amps. If you smear di-electric grease on the terminals that should help.
Old Dec 24, 2006 | 09:01 PM
wasup1357's Avatar
00 TL
so i probably would need a new battery? sry im noob in cars so i probably need to buy a starter kit or something? any recommandations for which battery to put in? and waht should i do first before putting in the battery? thanks
Old Dec 24, 2006 | 09:12 PM
fsttyms1's Avatar
You dont need to buy any thing special. IF when you get home it needs some attention look into it then. If its dead when you get home, Either put a battery charger on it, or try getting a jump start and driving it for awhile to see if it charges and stays charged.
Old Dec 24, 2006 | 09:31 PM
MOBB's Avatar
My OEM 2000 Tl battery, has lasted me 160k's (100k Miles) and is prabably about 6.5years old. It just died through the canadian winter.
Old Dec 26, 2006 | 12:16 AM
Tom Blasing's Avatar
is the Mighty Favog
When your motor is running the acid in the battery is heating up (normal). The expanding gasses from this heated acid is being vented out of the battery, as it should to prevent the battery case from bulging or cracking. When the car is shut off some of that gas is still being vented for a short period. When the gas outside the battery cools down it condenses back to a non-gaseous state and will collect on the battery posts (being lead).
I used to glue a penny to the battery case near the posts so the acid would attract to it before the posts. ehh...work for a little while till the penny got knocked off by something.
THEN (and to this day) I clean the contact between the posts and the terminals and make the connections as normal and then take bearing grease (lithium will also work) and coat the each terminal till no metal is exposed. I've never had a bit of corrosion ever since on any car or any battery.
Jul 16, 2017 07:33 AM
spoiler900
Oct 10, 2015 06:48 PM
samson_420
Oct 8, 2015 01:47 AM
hrothgar02
Sep 28, 2015 11:08 AM
