How long do HID's last?
They are supposed to last longer than the life of your car, forreal!!! I read that somewhere... On the other hand, I saw a MB E430, and one of the HID lights blew out
... The grossest thing I've ever seen
Shyne--High Intensity Discharge allover women who dare to go thare
!!!Shyne--High Intensity Discharge allover women who dare to go thare
They have a half life of 1000 to 1500 hours. That is the beam gradually weakens. About 1500 hours the beam is half the intensity of the original beam. Several hundred dollars to replace. (Part of the reason why they are 500 to 1000 options on most vehicles.
Are these bulbs covered by the 4yr/50K mile warranty? I hope they are covered, because I bought the factory extended warranty (7yr/100k miles) so when it goes out in year 5, I won't have to be hurtin' to pay for replacements.
DA
Originally posted by TLon19s:
The dealership told me the bulbs should last 100,000 miles.
Originally posted by -Rz-UA5:
THe HID on the TL last 2000 hours
and they cost 500$ each.....
Guest
Posts: n/a
$500 each?? WTF. that is insane. I thought $500 was for the entire HID unit. Wouldn't you just want to replace the bulb itself? Shouldn't be more then $10 or so.
aACURA
99 TL,SATIN SILVER EXT.,EBONY INT.,UNDERBODY KIT, HEADLIGHT FINISHERS, INSPIRE TAILS, PIAA 1700X FOGS,17IN BBS RK, GUTTER GUARD GRILL, HEADLIGHTS CLEARED,COMPTECH EXHAUST, COMPTECH SPRINGS, AUDIO ALL DRESSED UP, VIDEO UNDER THE SCREWDRIVER ;D
Originally posted by VICNYC_TL:
to correct that since i have bought an HID from Acura they do not cost 500, the are close to 250 bucks.....
uhh let me correct this for all of you since i have been talking to acura about the fact that there is a TSB in the HIDS because they are not keeping the blue color they are supposed to. this is due to an operating temprature problem with the bulbs. acura is working on a replacement bulb as we speak. i took my car in on a comlaint of the passenger side light being a different color compared to the driver side. after replacement of the whole light assembly including ballast and starter. the tech's called acura when the problem was still not solved after replacing the above components at a cost of about 250.00 acura responded by saying that there were working to correct the problem as a few cars have come in for the same complaint. i posted this earlier about a month or so back. if you have 2 defective bulbs you probly won't notice the problem unless you have another tl parked next to you with good lights. i had 1 bad and 1 good so they looked different. thats how i found there was a problem. anyway the bulbs cost 80.00 a peice. and they are supposed to last the lifetime of the car. i am sure there are exceptions though i am sure that some people may have a failure but in general they should out last the car they don't exactly burn out since there is no filiment but rather a spark that jumps a gap through Xenon gas. the lights are supplied with a 50,000 volt arc that is generated by the ballast unit. you should never attempt to touch or remove the light when on or look directly at the bulb when in use. and never tough the glass of the bulb as the oils from your hands will cause the glass to fail under intense heat. that may have been the cause of the above post of a falure of the bulb.
formerly 98 prelude type SH
Currently 2001 Acura 3.2 TL With Navigation Black/Ebony
Guest
Posts: n/a
On average an H.I.D. bulb will last about 3500 hours(This is according to Philipps)It requires 20.000 volts to start the bulbs little arc light display but only requires this blast for a millisecond once the arc is started it only uses 12 volts at 35 watts.This is comparable to a small fog lite bulb yet it puts out 3 times the light of a conventional halogen bulb.Jens
If you wanna stock up on these bulb, you can always stop by your neigborhood auto junkyard and look for some wrecked TLs with their HIDs in tact.
http://www.copartfinder.com
Look for one near you, I'm sure they'll be pretty cheap.
Knowledge is potential, Action is power.
<A HREF="http://www.geocities.com/phanthavong/mytl.html" TARGET=_blank>
</A>
</A>
i dont think there will be recall but if you complain about it to the dealer they should be able to replace the lights for you under warenty. unfortunatly at my dealer they tried all the bulbs they had in stock and all had the yellow color and they were told by acura to send all the defective bulbs back to acura and they are supposed to wait till acura sends out a bulliton that the problem has been fixed. acura will give a new part number to order the new lights from.
Jul 16, 2017 07:33 AM
