How do i shift?...
in the car...you have this knob. around the knobs are little numbers that say 1-2-d3-d4-d5....you can move the knob up and down through these numbers to shift =)
ok ok in all seriousness....u can either leave it in d4 or d5 or do one of 2 things:
1) put it in d5 then push it to the left, you'll be in sportshift mode. move up to upshift and down to downshift
2) gateshift by physically moving the knob up and down between 1-d5
shift
If you put the stick on sport shift you change the gears up and down. if your transmission has 5 gears, then the computer will shift fopr you from 1-2 or from 2-1. Where if you have a 4 speed transmission, then you can shift down to 1. If you forget to shift either way, the computer will do that for you. You'll notice that using the sportshift will use more gas. I use it in trafic to slow down and not waste brakes. It's fun but it's also nice to know that you can always have the computer handle the shit. If I had to buy a Porsche, it would be tiptronic. You get the best of both worlds.
MrHeeltoe
20
02-23-2023 01:54 PM
SidhuSaaB
05-30-2020 12:40 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Hines57
09-24-2015 01:58 PM
