How do I replace the drivers side headlight?
Old Jan 24, 2009 | 07:48 PM
yatahaze's Avatar
I can't really figure out how to replace the drivers side headlight. It's being blocked by some sort of plastic vent that doesn't look removable.
Do I have to remove the whole headlight assembly or is there an easier way?
Does anyone have any tips for doing this? Thanks.
Old Jan 24, 2009 | 08:07 PM
VoLLy's Avatar
Meridian
You will HAVE to take out the reservoir overfill bottle in order to get to the headlight.
Old Jan 24, 2009 | 08:09 PM
yatahaze's Avatar
But there's this big black tube thingy blocking the entire face of the headlight cover. That seems to be in the way more than the bottle... unless they are related.
Old Jan 24, 2009 | 08:16 PM
ftLauTL's Avatar
Ya....It's an Acura
what year is yours?
Old Jan 24, 2009 | 08:20 PM
yatahaze's Avatar
2003
Old Jan 24, 2009 | 08:52 PM
Mista Juice's Avatar
for the drivers side?
check the DIYs.. there are a couple threads i believe.. im not sure exactly which pieces you are talking about that are in the way though.. mine was totally clear when i did mine a couple weeks ago.. then again, i have a CAI, so everything has been taken out..
Old Jan 24, 2009 | 09:11 PM
fsttyms1's Avatar
You shouldnt have to remove the intake piping but to make it easier you can. Other than that there isnt any thing that needs to be removed.
Old Jan 24, 2009 | 09:39 PM
yatahaze's Avatar
It's the drivers side, we've already done the passinger side. It looks like intake piping but we have no idea how to remove it, can't see any method of removing it. That's why we're asking if we need to remove the whole headlight assembly.
Old Jan 24, 2009 | 10:41 PM
VoLLy's Avatar
Meridian
shoot, nvm, i was referring to the driver side high beam.
Old Jan 24, 2009 | 11:00 PM
yatahaze's Avatar
To clarify, it's the drivers side xenon hid bulb I'm trying to replace... not the whole assembly either, but I was wondering if I needed to take the whole assembly out just to change the bulb.
I checked around and couldn't find much info on replacing the drivers side. Found info for passengers side and got that done.
Old Jan 24, 2009 | 11:28 PM
yatahaze's Avatar
I already put the long plastic cover back together so I can't take a picture of the actual piece I'm talking about... but here's a pic anyways.
Old Jan 25, 2009 | 01:33 PM
yatahaze's Avatar
So does anyone know what I'm talking about? I'm gonna open it up and work on it again today... I'll be able to get a picture of whats actually blocking it.
Old Jan 25, 2009 | 03:22 PM
yatahaze's Avatar
Stumbled upon http://www.acura-cl.com/forums/showthread.php?t=689886
Old Jan 25, 2009 | 04:43 PM
yatahaze's Avatar
For Non-Type-S owners, there is an annoying plastic piece blocking the headlight that just requires brute force to remove.
Old Jan 25, 2009 | 04:49 PM
fsttyms1's Avatar
Forgot about the horn. Yes just yank up on that. Many of us dont have that as we have removed our resonators (that part and the box below it)
Old Jan 26, 2009 | 03:17 AM
spoka's Avatar
That's the snorkel on the resonator, I've always found it easier to replace bulbs and ballast with the headlight off, which requires the removal of the bumper.
It may seem hard but its actually only a couple of clips and 2 screws in each wheel well, only takes me a couple minutes to remove mine.
Old Jan 26, 2009 | 04:59 AM
Rajca's Avatar
wham bam thank you ma'am
x2
Old Jan 26, 2009 | 07:36 AM
fsttyms1's Avatar
The 3-5 min it takes to take just the bumper off you could have replaced both bulbs
Old Jan 26, 2009 | 01:13 PM
yatahaze's Avatar
Already done the hard way :P
Old Jan 26, 2009 | 01:38 PM
ZEUS'O3TL's Avatar
Low & Slow w/Dubz On My
did u remove the intake resonator?...datz a free mod right there and ur saving urself like 50 pounds...lol...j/k...but it sounds nicer when u rev it a lil...
csmeance
Jan 7, 2026 06:25 PM
Feb 25, 2020 09:57 AM
nanos
Nov 12, 2015 08:41 PM
Ny1718
Sep 11, 2015 09:21 AM
08 NBP TL
Sep 8, 2015 08:49 PM
