How can I detect the tranny proble?
Old 08-15-2002 | 04:02 PM
MD'sTL-s's Avatar
Can you tell me how I can tell if my tranny is going bad? Is it easy to detect the problem or do you have to be a mechanic? Please give me some advice?
Old 08-15-2002 | 04:04 PM
yahtzee's Avatar
No, you are a dork.
Get on the highway going about 70 and drop it into 2nd gear....you will know then.
Old 08-15-2002 | 04:10 PM
MD'sTL-s's Avatar
Is it safe to drop it to 2nd gear? I don't want to damage the car.
Old 08-15-2002 | 04:12 PM
yahtzee's Avatar
No, you are a dork.
WOW.......I was totally kidding. I really have no idea.....I do know that throwing it into second gear will give you tranny damage if you already dont have it....
Old 08-15-2002 | 04:38 PM
juniorbean's Avatar
You'll feel the tranny slipping... so it will be pretty easy to diagnose. Also, if the car isn't shifting properly in auto mode then you should probably make a service appointment.....
Old 08-16-2002 | 11:34 AM
BlueXTC's Avatar
ehh...i shifted down to 2nd gear on the highway few times...i think the fastest i was going was 60tho... i feel like the rpm needle doesn't see enough of the redline...so i help them reunite once in a while...
after all it's made by honda...world renown for naturally aspirated engines.... redline the sh1T out of it!
Old 08-16-2002 | 06:02 PM
numbaonexstunna's Avatar
i think my tranny might go out...and im almost out of warranty....here are some symptoms:
when i accelerate slowly, the gas pedal shakes a little bit around the low gears at 2000 rpm....is it the torque convertor??
sometimes when it goes from first to second, it feels like it tried to shift once...failed...and then shifts to second
when i drive hard for a little bit, if i put my hand against the panel where it says "park,reverse,neutral,drive, etc" its kinda warm....
i need to know if i should keep driving like this or take it in b4 the warranty's gone
Old 08-17-2002 | 01:49 PM
PAW
Warmth
I don't believe the tranny extendes under the console. Sorry I have crawled under the car yet. The engine is transversely mounted (i.e., sideways in the engine bay) and the chassis is FWD. A RWD will have the transmissions between the front seats. It's probably heat from the exhaust pipe.
Pham Alvan
05-18-2021 07:48 AM
Charles Bennett
01-28-2018 09:53 PM
Pham Alvan
03-16-2016 10:17 AM
xsilverhawkx
10-05-2015 12:00 PM
Quick Reply: How can I detect the tranny proble?
