How to adjust your headlight's aim (2002 TL)
Old Nov 9, 2001 | 10:19 PM
daverman's Avatar
OK, after looking around unsuccessfully for clear instructions on how to adjust the vertical aim of my headlights, I decided to make some instructions on my own
All you need is a Philips-head screwdriver with a reasonably long stem (about 4" or so).
Your headlight's vertical aim can be adjusted by turning a pair of aiming screws. These screws have crown-like gears on their heads. You insert your screwdriver at right angles to the crown. As you turn your screwdriver, the crown will rotate. You'll see what I mean when you actually do it yourself.
Here are where the aiming screws are located. The screws are actually on the rear side of the headlight housing. The arrows only show their approximate location when seen from the front of the car.
Old Nov 9, 2001 | 10:24 PM
daverman's Avatar
Here is the location of the screw for the passenger-side headlight. Insert your screwdriver into the slot in the plastic sleeve, perpendicular to the screw shaft. The "teeth" of your screwdriver should engage the teeth of the crown. You should be able to turn the crown by turning your screwdriver.
Old Nov 9, 2001 | 10:26 PM
daverman's Avatar
Here's the adjustment screw on the driver's side. This side is very cramped, and you need to use a screwdriver with a long stem.
If you look closely at the bottom left of the larger picture, you can make out a semicircle with a "U" and "D" embossed on the plastic trim. This is a depiction showing that turning the screwdriver clockwise will aim the headlights up, and turning it counterclockwise will aim the headlights down. You can find the same markings on the passenger side.
Old Nov 9, 2001 | 10:29 PM
daverman's Avatar
There you have it!
Helpful hint: leave your ignition key in the "Accessory" position (first click after "Off") when adjusting your headlights. This will prevent the computer from switching off your lights after 15 seconds of inactivity.
Old Nov 9, 2001 | 10:46 PM
thank you very much... now I think I can blind some people
Old Nov 10, 2001 | 12:44 AM
Ex TL-S owner
looks good! I already aimed mine higher.........I blind everyone in front of me. It's great cuz they get out of my way.
Old Nov 10, 2001 | 01:38 AM
AKRY's Avatar
MB-Fanatic w/TL-S
How high was your stock HID beam height?? I feel that stock setting is more than adequate....
P.S. For my car, the top, flat part of the headlight beam(when stop behind a car, approx 1 ft in between)is about 1"-1.5" higher than TL's trunk lid cut out(where trunk lid and bumper meet).
Andy Kuo
Old Nov 10, 2001 | 08:52 AM
daverman's Avatar
I have to raise mine about 2 deg. or so since it is very difficult for me to see down the highway at night. The light cuts out way too early ahead of the car and it makes for dangerous driving!
Old Nov 10, 2001 | 09:09 AM
SimTypeS's Avatar
...and then there was One
Well, of course that will happen when you outrun the headlights doing >120mph, daverman.
Old Nov 10, 2001 | 09:48 AM
Ex TL-S owner
Andy Kuo
I had to raise up due to lowering my car.
Old Nov 10, 2001 | 10:37 AM
Bitium's Avatar
Retired MOD
Lightbulb
Nice, what about horizontal aim?? If you are going to explain something then fully explained.
Old Nov 10, 2001 | 12:00 PM
tdoh's Avatar
Man, we got a tough audience out there...
Tony
Old Nov 10, 2001 | 11:00 PM
daverman's Avatar
Yeh...
daverman's Avatar
Feel free to take your own photos and post them!
Old Nov 11, 2001 | 02:02 AM
Bitium's Avatar
Retired MOD
I might.
Old Nov 12, 2001 | 02:37 AM
bebber's Avatar
I adjusted my headlights using a wrench to turn the metric bolt atop the metal vertical adjusting crown screw thingamajig, but I guess that a screwdriver in the teeth could accomplish the same thing if you're careful not to strip the teeth.
The Horizontal adjustment is further to the exterior sides of the headlights. There's like a black screw like gear that you could fit a phillips screwdriver into and turn it if I remember correctly.
I like to aim my HID's high to light up freeways signs.
Old May 9, 2002 | 06:19 PM
njzprettyboy's Avatar
is that how to do 2000 TLs as well? please let me know
Old May 10, 2002 | 01:25 AM
Davediego's Avatar
4dr & I like it that way
Use a 10mm wrench, its ALOT easier then trying to get a screw driver in there
same place, again I used a 10mm when I raised mine after getting springs, makes this very easy.
Old May 11, 2002 | 09:06 PM
FLL Type-S's Avatar
Iconoclast
Check out this thread. It has some info and also links to additional info on how to do this on a TL-S.
Headlight Levelling
Old May 11, 2002 | 10:41 PM
AKRY's Avatar
MB-Fanatic w/TL-S
Headlight Levelling
Why's the address censored out??
Andy Kuo
Old May 12, 2002 | 09:26 PM
FLL Type-S's Avatar
Iconoclast
That's weird. I don't know why that happened.
Here's the link again.
Try Again
Old May 12, 2002 | 09:37 PM
FLL Type-S's Avatar
Iconoclast
For some reason the name of the site keeps getting censored out.
Try substituting the stars with a c u r a w o r l d, but with no spaces between the letters.
Old May 12, 2002 | 10:39 PM
Vffr1's Avatar
Team Anthracite President
daverman,
What an excellent post. Thank you so much, since I lowered my car, this adjustment was needed.
As far as the person asking you to do a "complete post" not sure you could of been more complete on a "vertical" headlamp adjustment, wink wink, nod nod.
Thanks again buddy!
Mike Smeezy
Old May 13, 2002 | 05:36 AM
A cur a Wo r l d is a bad word around here I think headlight adjustment would make a good FAQ, if it isn't already there...how about it moderators???
Old May 13, 2002 | 12:13 PM
Dvs rice's Avatar
does anyone know how to do it for a 2001?
Old Aug 13, 2012 | 04:58 PM
Devanacura2003's Avatar
3rd Gear
Thanks this thread helped me out!
Old Aug 13, 2012 | 06:37 PM
MilwaukeeDave's Avatar
Holy 10 year bump!
Old Aug 14, 2012 | 01:33 AM
ua5inspire03's Avatar
11 year bump
Old Aug 15, 2012 | 08:04 AM
ktamasama's Avatar
5th Gear
wow 11 years. thanks for the info!
Old Mar 20, 2014 | 04:23 PM
cidvanski's Avatar
2018 RLX Sport Hybrid Adv
Thanks guys...I just adjusted mine after blinding people for the past 18 months lol!
Old Mar 22, 2014 | 10:24 PM
coronaman's Avatar
Anyone know how to adjust the fog lights?
Old Mar 22, 2014 | 11:13 PM
Skirmich's Avatar
^ There is a small hole in the lower section of the bumper so you can use a screwdriver and adjust the Fog Light.. BUT Fog Lights dont aim high, not even high enough to light your knee unless you remove the restrictor shield and that will require to remove the glass (Good if you want to upgrade to lexan!)..
Old Mar 23, 2014 | 12:40 AM
coronaman's Avatar
Just bought my tl a few hours ago. Will have to look to see what they look like but definitely want them higher. Lexan=plexiglass?
Old Mar 23, 2014 | 02:02 AM
Skirmich's Avatar
^ Yup! http://www.ebay.com/itm/02-03-ACURA-TL-TL-S-Lexan-Fog-Light-Lens-A-PAIR-of-foglight-lenses-/231071936861?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AAcura%7CModel%3ATL&hash=item35ccf5f15d&vxp=mtr
That is the guy which probably most of us got the Lexan Upgrade, Myself Included
From this:
To This (Same Fog Light!):
Their Lexan is so good, There are actually installed in that Pic ^
Old Mar 23, 2014 | 10:00 AM
coronaman's Avatar
How much does the lexan upgrade cost. Where do I get them my glass lenses are B R O K E N! But the bulbs inside still work. B-)
Old Mar 23, 2014 | 11:03 AM
Skirmich's Avatar
I just put a link to ebay in my previous post :S
Old Feb 24, 2021 | 09:10 AM
mikes black ac's Avatar
i see nothing no pics or video
aznacuraguy3
3G TL Photograph Gallery
Jun 25, 2008 12:16 PM
toddpa332
1G TL (1996-1998)
Oct 27, 2006 09:44 PM
gman44116
Jul 19, 2006 12:16 AM
OneQuickFWD
Oct 14, 2002 06:20 PM
bsaber41
1G TL (1996-1998)
Jan 24, 2002 10:27 PM
