High OUtput Alternator for 02 TL-S
Anyone have any expierience with putting in a high output alternator in a 2002 TL? I see one on 4alterstart that is 180 amp but it says that it is for up to 01 do you guys think it would still fit in my 02? If anyone else knows of any other brands please let me know. Thanks for any help.
Originally Posted by NaturalTLS
check out ohio generators they have some or u can send in yours to be rewound.
I am going to run Image Dynamics components in the door and an IDMAX sub. I am going to use a Phoenix Gold Xenon 200.2 to power the comps and a PG Ti800 to power the sub. Both are class A/B amps so they will draw alot of power so I was thinking of putting in the 180 amp alternator. I would try not to turn it up to max but the 200.2 is supposed to draw 60 amps at max and the PG says it would draw 100 amps at max. But I don't think I would turn it up so loud so i was thinking the 180 amp alt would do me well. Just sometimes I would like to turn it up really loud. I heard mine has a 105 amp alterntor not 130
Engineering
Engine Type 3.2-liter 24-valve VTEC™ V-6 engine
Displacement 3.2 liters (3210 cc)
Horsepower (SAE net) 3.2 TL - 225hp @ 5600 rpm
TL Type S - 260hp @ 6100 rpm
Torque 3.2 TL - 216 lb.-ft. @ 4700 rpm
TL Type S - 232 lb.-ft. @ 3500 rpm
Redline 3.2 TL - 6500 rpm
TL Type S - 6900 rpm
Compression Ratio 3.2 TL - 9.8:1
TL Type S - 10.5:1
Valvetrain SOHC 24-valve with Variable Valve Timing and Lift Electronic Control (VTEC™) system
Fuel & Induction System Programmed Fuel Injection (PGM-FI)
Emissions Control Electronically controlled EGR
3.2 TL - LEV in 49 states (ULEV in CA)
TL Type S - LEV in all 50 states
Bore & Stroke 3.50 in. x 3.39 in. (89 mm x 86 mm)
Engine Block Aluminum alloy with cast-iron cylinder liners
Cylinder Heads Aluminum alloy
Ignition System Direct ignition system with knock control
Battery 12V, maintenance-free
Alternator 3.2 TL - 105 amps maximum
TL Type S - 120 amps maximum
Tune-Up Interval No scheduled tune-ups for 100,000 miles*
there you go just leave the H/O one you have in.
BTW I think as a general rule the current draw(amps) is about 10% of the power output (watts) I think your fine and even if you get close to 100amps of draw it'll be momentarally and a cap can help ease the load.
TL Type S - 10.5:1
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
