HID's question.
Old Feb 12, 2013 | 11:43 AM
DanTL-S's Avatar
HID's question.
Well one day I was going to work, both lights worked perfectly, so i get out of work 7hours later and my driver side lights gone. I go home, change a fuse a.bam! Its fixed! Or was for 2minutes. the light would go out but the fuse wasnt burnt(the first one was) So the fuse isnt burnt but it did make a loud pop and the light dies again.
I bought a used ballast to solve the problem, and it did. So i have matching bulbs but my lights dont match. Does the ballast still need burn time? Ive been driving for about a week and it doesnt seem to be getting anywhere as bright as my other light.
Is this ballast going bad too?
Old Feb 12, 2013 | 11:46 AM
DanTL-S's Avatar
I also wanted to know if the ballast has anything to do with the lights being different and if it still needs burn time since it is used.
Anyone know if getting an aftermarket HID set for 100$ would be a fine replacement?
Old Feb 12, 2013 | 11:26 PM
DanTL-S's Avatar
Anyone know?... Please
Old Feb 13, 2013 | 07:54 AM
3.2TLc's Avatar
Check your wiring connections and grounds.
Any existing moisture will play havoc with the system.
Many other Ziner's have had good luck with the newer compact and waterproof aftermarket kits available
through our sponsered vendors.
Old Feb 13, 2013 | 10:08 AM
DanTL-S's Avatar
Does HIDxtra sell them for a reasonable price? Class is starting soon and I've been meaning to check their site but it somehow slips my mind to do so everytime.
Old Feb 13, 2013 | 10:21 AM
3.2TLc's Avatar
Less than $100...and more with discount from 'Ziner's !
Check them out for more info, DIY isn't all that difficult....mounting & splicing !
Old Feb 14, 2013 | 08:21 AM
DanTL-S's Avatar
Alright awesome!!
Side note: I found two cracks in each of my fog lights. After a car wash they were moist inside, they obviously didn't work but they do again once it dries up. Could that have done something to my lowbeams with my first ballast?
Old Feb 14, 2013 | 08:23 AM
might have.
water and electrical components dont play well together.
inspect the ballast to see if they got wet!
Old Feb 14, 2013 | 11:06 AM
01tl4tl's Avatar
see the 100000 treads on the weak lens seal for headlights- thats why a used ballast wont fix the problem, water kills ballast and capacitor..delicate electronics, high voltages and rust--not cool-
(make new lens for fogs from lexan to fix that issue)
new bulbs need 50 hours run time to fully burn in
new electrical need 0 time --they just put out power
hidextra.com 59$ kit D2 /r or s bulb base depends on year
get the 5000k bulbs to best see road with
stock were 4300
dont get any exta parts- not needed for us,,just the standard kit
look up by make on website then call to order- ask for JAY, he is sharp
tell him acurazine member
look online for 10% off coupons..or ask on phone
they have changed the standard kits ballast to a better design recently
and offer a high lumens output ballast in 35watt for a 100+,,
I would stay on standard 35 watt for average drivers and budget oriented,,
$59 for all you need except 2 dollars worth of connectors at parts store
Old Feb 14, 2013 | 11:12 AM
01tl4tl's Avatar
note: stock ballast is directly below the air vent/drain hole on bottem of housing=
danger will robinson!
kit allows mounting of ballast away from that area,,and capacitor is built into the cord from ballast to bulb
stock is mounted on housing
Old Feb 14, 2013 | 11:29 AM
DanTL-S's Avatar
Very awesome information man! Well I know my HIDs were not stock because even when I had to drive with one headlight the 5lane freeway was lit up for about 10-15feet in front of me.
So i should just ditch my current ballasts/bulbs and get a new one from HIDxtra?
Old Feb 14, 2013 | 05:20 PM
3.2TLc's Avatar
How do you know that the "HID's" unit isn't stock oem ?
The HID bulbs will vary with intensity and brightness, depending upon age, brand and rating. If not a matched pair at time of replacement, the bulbs may operate differently !
Old Feb 18, 2013 | 03:35 PM
HIDXTRA's Avatar
Former Sponsor
Hello DanTL,
If you are ready to order, please visit www.hidextra.com or call us at 860.821.8212 and please use coupon code: newfb for 15% OFF
Thank you.
HIDeXtra
Old Feb 19, 2013 | 08:59 PM
01tl4tl's Avatar
Jay recently hooked me up with a set for my neighbors car,,next we do my bike!
Old Feb 20, 2013 | 10:51 AM
DanTL-S's Avatar
On your bike? Thats awesome! I semi-fixed my HID problem. Theyre still not as bright as before so ill be visiting HIDxtra
Old Feb 20, 2013 | 03:09 PM
01tl4tl's Avatar
bulbs lose intensity and color as they age
rusty innards of ballast dont put out full power to bulb
any gen2 TL is due for new system parts and bulbs based on age/time in use
just saw the new kit= good: shorter power cable ballast to bulb and more flexable = easier install
new bracket may actually be useful~
ballast slightly larger than before but still smaller than a deck of cards
seems better quality too
Good package, fast shipping
Old Feb 25, 2013 | 06:29 PM
HIDXTRA's Avatar
Former Sponsor
Have you ever wonder how HIDextra's HID kit is more superior than other aftermarket HID kits? Read this blog, and you will know why!
http://blog.hidextra.com/hidextra-hi...d-kit-quality/
Old Feb 26, 2013 | 01:26 PM
HIDXTRA's Avatar
Former Sponsor
Many customers ask us, what makes a good hid kit from a bad one? Is it the xenon bulb? Is it the HID ballast. To put it in simple terms, it’s both and a little bit more.
We encourage you to read http://blog.hidextra.com/hidextra-hi...d-kit-quality/ so you will know why HIDextra kit is more superior than other aftermarket HIDs.
Old Mar 1, 2013 | 08:35 PM
Glockgen4's Avatar
DDM tuning $30 a set. fast shipping. great lights. Have had them for 3 years in my Tundra. Awesome!!!!
What I dont know is if replacing HID's on a car that already has them, are they new set just plug and play or what. I wanna order a set for my car as the ones I have are not so good...
Old Mar 5, 2013 | 11:57 AM
HIDXTRA's Avatar
Former Sponsor
Hello Glockgen4! Thank you for your interest in our HID Kits.
If you are only replacing
your D2 bulb, you can simply swap the bulb. But we strongly recommend you buy the entire kit from us as we tune the ballast and the bulb to be matched with each other. We cannot guarantee proper functionality with other ballasts in the market.
Please provide your CAR Make / Year
/ Model so we can assist what HID Conversion kit you would need.
Thank you.
HIDeXtra
Old Mar 5, 2013 | 02:17 PM
Glockgen4's Avatar
Thank you.
HIDeXtra
2001 TL. I just want to do the Low beams. The stuff in there now puts off a purpleish light and is kinda week. I emailed the tech guys at DDM and they said that the kits should work.. But I don't know if I should delete the old system or what.... I have never installed HID to a car that already has them..
Old Mar 5, 2013 | 06:06 PM
01tl4tl's Avatar
gloc ck the many threads or diy on this
you toss the old stuff which is mounted under/inside light housing
install new stuff is simple
all you have to do is cut off a connector and install a new connector from those wires to the new ballast
if you can make a splice you can do this
hidextra `kit` works for conversion for others
for us, its a complete replacement of working parts and bulbs
already have correct power source and fuse/relay installed
do you want a kit that might work or should work..or one that hundreds/thousands of us gen2 are currently running?
59$ is pretty cheap, would I trust 30 dollar kit? not me
Old Mar 5, 2013 | 06:09 PM
01tl4tl's Avatar
note: pink/purple tint = age death for bulbs
pretty soon it will stop working at all
Moisture issue cars: one light will go out driving, can be restored by flikking switch
may change sides,,blow new bulbs etc...
new bulbs need 50 hours run time to get fully bright and color set = burned in
Old Mar 6, 2013 | 07:17 PM
Glockgen4's Avatar
Thank you for the reply, it helps a lot..
Do I trust $30 kit, absolutely yes. I had 2 of these sets in my Tundra. One low beam set and one fog light set. Had them for 3 years and received nothing but compliments on them. Super clean light that was awesome. I no longer have the Tundra, I thought about pullin them out, but I didn't....
Edit to say, I really don't care where I buy them from, its not that at all. I just wasn't sure how they matched up, no matter where they come from.....
Old Mar 8, 2013 | 11:22 AM
01tl4tl's Avatar
every ziner running hidextra has positive comments
one or two ballast probs reported more than a year ago, those were warranty no prob,
and now a better ballast with capacitor built in and all sealed inside the case
Im was happy enough to install a set on neighbors car too!
Old Mar 8, 2013 | 11:13 PM
acura_dipset_tl's Avatar
AM To WDP In My Garage
Can't go wrong with hid extra, I've personally have bought 8 kits from them and had great results.
Jul 16, 2017 07:33 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
