HID issues....
Old Dec 19, 2008 | 12:31 AM
Exclamation HID issues....
Ok I got a 99TL.
One HID not working. When I turn the light switch on i hear a slight rattle. It went out but not sure if ballast or bulb? Which could be more likely?
The bulb went out then it worked first had to switch on and off a couple times to make it work. But now no luck just the rattle when i turn the light switch for the HID driving light.
Just in case this is not for the fogs sine i have none.
History- HID bulb 6000K phillips about 4 yrs old one ballast original the other also 4 yrs old but forgot which side is newer damn it.
Anywhere close to queens NY that i can buy ballast or lights and get a deal. Appreciate it
Old Dec 19, 2008 | 12:33 AM
TLTypeSilver's Avatar
Registered TL Driver
Usually its the ballast that goes out first.
Old Dec 19, 2008 | 02:41 AM
Type-SuperFast's Avatar
Another TL Lover
same happened to me, the bulb went out first, replaced it, then a week later my balast went out its a chunk of change replacing these things
Old Dec 21, 2008 | 10:46 AM
Papa_Sean's Avatar
Originally Posted by TLNY
Ok I got a 99TL.
I have a similar problem but no rattle. After searching it seems the best thing to do is switch the bulbs from one side to the other. If the same side still goes out then its not the bulb....I tried to do this but its cold outside and a pain in the ass getting to the bulb and pulling it out Im having a shop install my brakes next week so Im just going to ask them to do it.
Old Dec 21, 2008 | 10:52 AM
Rajca's Avatar
wham bam thank you ma'am
try swapping out the bulbs from side to size, if the brunt out bulb is on the pass side, and u swap the bulbs, the drivers side should not turn on and the pass side will be on, tells u its the bulb. if the pass side is still out, change the inverter and ballast out the same way u didnt the bulb. will narrow down the problem and u dont have to waste more money on what u think is out when its good.
Old Dec 21, 2008 | 02:16 PM
inyong1988's Avatar
If you want to stay in safe and reduce the amount of work, when you replace your light, change the whole set up. (bulbs and ballast at the same time even one of them are still in a good working condition.)
Old Dec 21, 2008 | 06:34 PM
Slowpoke842's Avatar
Subaru Guy
When the light from the bulbs turns pink, that's probably bulb, not ballast, correct?
Old Dec 21, 2008 | 06:35 PM
inyong1988's Avatar
you're correct. As long as bulbs turn on, ballast are straight.
Jul 16, 2017 07:33 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
