HID Bulb is it out?/
trill recognize trill
It was purple then pink then it went out, that means i need a new bulb right? i checked the fuses and they weren't blown. recommendations for a new bulb? thinkin about 6000k
bulb is shot. Id find a philips or orsam bulb and i would replace both at the same time
Former Sponsor
You could also buy a set of the upgraded KAIXEN HID bulbs that are 6000k. I have a few in stock.
https://acurazine.com/forums/sponsored-sales-group-buys-10/kaixen-hid-kit-groupbuy-330409/
Shogun Assassin
My driver's side HID is out....I checked the fuse and it was blown. I changed the fuse but nothing happened, so I'm taking it in to the stealership for them to take a look at it. Hooray, more money out of my pocket to fix another problem with this car.
Sippy Cup (x2)
Shogun Assassin
I took it to the dealer and they swapped the bulbs, but it didn't work. They're still not sure what the problem is...but they only had it for like 30 minutes so they'll need it for longer. What's really fucked up is my daytime running lights (DRLs) are on, even after I turn on the lowbeams. I also noticed the fuse for the HID was burnt out, so I switched it and then the new fuse burned out too.
Sippy Cup (x2)
Kinda sounds like there may be a short in the ballast. I don't know if that would cause the fuse to keep on blowing though. Maybe it's a ground wire that came loose. Well, either way, I guess the dealer will figure it out.
Shogun Assassin
Took it in, turns out the Control Unit crapped out....it had corrosion on the surface and it smelled burnt. I suppose it was damaged from the accident last year...whatever. The bulb itself was fine. Well, $630 later my lights are working again.
AmplifiedDetails
09-24-2015 02:55 PM
