HID Ballast/System Problem
Old Aug 3, 2010 | 02:23 AM
mnjeepmale's Avatar
I have '02 TL-S and over the past 6 months I've been experiencing a problem with the drivers side headlight.
About 1-2 times every few weeks the headlight on the drivers side will not turn on or will turn off while driving. Most of the time I just turn the headlight switch off, wait 10 seconds and turn it back on and the headlight will work again.
From what I have read this is a problem with the ballast showing some wear or electrical board is corroding. I was looking to buy a brand new one and take the bumper off to replace it but a new one is about $300 bucks. That's a lot of money.
Should I just throw $300 bucks and buy one or does anyone have some suggestions?
Old Aug 3, 2010 | 03:41 AM
YeuEmMaiMai's Avatar
swap them around first and see if the problem stays in the same spot or moves.
if problem moves = replace ballast
if problem remains = find the fault in the wiring
Old Aug 3, 2010 | 05:41 AM
my.daily'tl''s Avatar
Always Working In
X2 swap bulbs around first. The problem you describe was like mine and it was the lamps.
Old Aug 3, 2010 | 06:43 AM
totaledTL's Avatar
Read this (DIY section):
Ballast/Inverter Repair
https://acurazine.com/forums/showt...llast+inverter
Old Aug 3, 2010 | 08:52 AM
ILLZ's Avatar
Had this problem too, just bought new bulbs installed them and all is well.
Old Aug 4, 2010 | 05:09 PM
mnjeepmale's Avatar
I think I am going to start by replacing the bulbs first. Where do most forums member buy their bulbs?
It looks like I can get to the passengers side bulb easy but the drivers side looks a little more difficult.
If it still happens after the bulb is replaced, then I most likely I have a ballast or electrical problem.
Old Aug 4, 2010 | 06:03 PM
Always Working In
did you try swapping the bad side with the good side one first? may not be a lamp problem...but... HIDextra sells them in our vendor section. check with him. stock color is 4300k - best output.
driver side - you have to remove the overflow coolant reservoir for room. a lil cramped but it can be done.
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
