Helpful advise for those who want to clear their headlights
Allright guys, ive been thinking about this one for a while and i am sure that it will work. What is the hardest thing to do while clearing the lights? Its not taking them apart. Thats easy when you use a heatgun. The hardest thing is, believe it or not, putting them back together. Why you ask? Leaks. Leaks are common when clearing out your headlights. If you dont do it right, you get moisture and then all sorts of headaches. SO i think i have found a solution. After the lights are taken apart and cleared, and the old adhesive is removed from both sections of the lights, you should use new sealant/adhesive and press the two pieces back together. This is the hard part. How to clamp the two pieces back together to ensure good adhesion?? Use these suckers...1 inch or 3/4 inch Binder Clamps
Go to your local office supply and purchase like two boxes of these. If you place several, evenly spaced apart all around the lip of the seam, it should provide more than enough pressure to keep the pieces from forming a bad seal. Once you have all the binder clamps on, use your heatgun and heat the seam around the edge to make sure that the adhesive has penetrated. This will also heat the plastic housing and make it conform to the correct shape, thus providing for a better fit. I will try this when i help Elegant-TLS clear his lights. Whenver that may be. But if you are thinking of doing this, try it out. I think it will work perfectly.
![](http://www.officedepot.com/pictures/SK/SM/825182_sk_sm.jpg)
4dr & I like it that way
Nice tip but I need help getting them apart. I tried clearing mine once, held a hair dryer on hot/full blast on it for about 15 mins and while the adhesive got soft, I felt like I'd break the casing if I kept trying to pry it apart... so I gave up
johnnyb_s . .. this might sound krazie but getting it apart is easy . . . all u do is place the headlight in the oven for 5 minutes in i think if i remember right . . like at 200 and take it out and the front lense should come off with no ease at all . .really ease and quick . .. not much know this technique.
Has anyone actually tried out the oven technique? It sounds plausible, but my concern would be the plastic deforming from the heat.
Nice tip, Im doing mine this weekend, and will definitely try the clips out.
Im also going to paint the housing black, should I use heat-resistant paint, or will any kind work ? If anyone has painted theirs, please recommend a brand that you liked.
johnnyb_s - How long did it take you to pry apart each housing ? I'll be using a good heat-gun.
The first set of lights I did took me about 3 1/2 hours to remove the lights, clear them, and seal them back up. I used a hair dryer on low setting BTW. The next set I did I barely used any heat because I knew how to go about prying them apart. I had some help from BadazzTL and JPritch, so it went a lot faster, especially when it came to removing all the old Honda bond. Very important for a good re-seal! Whatever you do, DO NOT use alcohol to remove any fingerprints, etc from the chrome-painted portion of the lights because it will remove the chrome paint. It won't really matter in your case though because you are going to be painting them black. I used clear silicone to seal them back up and have no problems at all. Good Luck! And remember, take your time and work slow. I would say start early on a Saturday morning and allow yourself the day. You won't need all that time, but it is always better to give yourself more time in case the unexpected happens, which just might. Let us know how things work out.
BlingBling INSPIRE 32V
Originally posted by Vffr1
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
I'm sorry guys, what is "clearing your lights" Clearing them of what? Is that moving them to the outside position?
Thanks,
Mike Smeezy
Thanks,
Mike Smeezy
![](http://www.acura-cl.com/forums/images/smilies/rofl.gif)
Clearing H/L means taking the orange deflector out!!!
Team Anthracite President
Looks like you were just a tad late with that edit Vffr1
Mike Smeezy
Yeah, like when I figured it out, I wanted to remove it so I didn't look like a fool :o
Originally posted by JPritch
Did you ever get your car to quit smoking cigarettes?!?!?
![Cool](https://acurazine.com/forums/images/smilies/cool.gif)
I'll have to get those pics from BadazzTL to post for everyone. I think I was losing about 5 horses from all that "bad air"
one thing bout using a heat gun is that u made your lens a lil foggy . . not a big difference but if u look close . . u might see a lil fog . . i dont know .. thats what i heard
True true, i wont deny it. I did destroy a light housing when i cleared my lights. But i was a newbie when i did it and it was a rookie mistake. It wasnt from the heatgun tho, it was from using it incorrectly.
It wasnt from the heatgun tho, it was from using it incorrectly. The heatgun works marvelous as long as you use it correctly.
Can you explain this more pleez. Were you rushing it and heating too fast ?
Originally posted by payyourtoll
Nam-
Nam-
mada51589
05-03-2022 08:54 PM
dlknight
09-02-2015 10:42 AM
