Help Vsa Light On With Bass
Now that's some HEAVY bass!
When the air pressure from your woofer is "PUSHING" you around a corner and causes the VSA light to come on to correct for it... you've got some sound system!
Take it to the track, then point the woofers out the back and "light the afterburner" with some sinewave bass notes... I bet you'll decrease your 1/4 mile times! LOL
Re: Help Vsa Light On With Bass
Originally posted by notstr8
Hey has anybody had the problem, that when HEAVY BASS hits the VSA Light comes on and only resets when you turn the car off and on ?
Re: Re: Help Vsa Light On With Bass
Originally posted by str8acura
well... that cant be normal and i suggest u dont take it to a dealership... it will probably be useless. only other way to probably get that fixed is to take it to whoever did the install... see if they can help. btw... what tl do u have?? im in kendall. you?
Don't take it to the dealer. JUst think what are you going to tell them. My stereo system is f#3king up the car? They will just sit their and laugh or they'll charge you an arm and a leg for doing a checkup.
Mr.T
Re: Re: Re: Help Vsa Light On With Bass
Mr.T
Mr.T
Are you running a crazy audio system that could be drawing more power than your car can provide? Driving heavy bass would probably require more power consumption. Maybe it is drawing too much power and the VSA light is coming on because the alternator isn't sufficient??
Just a guess.......
Just a guess.......
mine does it too.. scared me to death the first time it happened.. usually if i turn it about 1/2 way up, i have a 2 farad cap, optima yellow top, 2x12's, and a kenwood 1800watt monoblock. my classic mini however, has just a yellowtop, jl 1000/1 amp 1x10" L7kicker solobaric, 45 amp alternator
, and the bass will straight shut the car off while driving.... awesome... (and just to bragg it put down 133.4db in a SPL drag....didnt win but its just a 10.)
mada51589
Jan 9, 2025 04:40 PM
Rob144
Sep 21, 2015 08:18 AM
