Help-Transmission? code p1750,p1676
Old May 11, 2014 | 02:32 PM
gooduser's Avatar
5th Gear
Unhappy Help-Transmission? code p1750,p1676
My car is 2001 TL, 170k, runs perfect until yesterday. I don't have much experience on diagnosis. My car's engine light and TCS light were on simultaneously when we drive a in parking lot, after a 2~3 mile drive on a bumpy road. After restart the car, TCS light is off. engine light is on again.
When driving, feel hesitation exist during fast acceleration. Feel like it is not as powerful as before. But if I drive smoothly, the car works fine.
Get the code p1676 and p1750. The dealer suggest replace the transmission and quote me $4000. Got scared... Is it really a transmission problem? What the normal price to rebuilt or replace a transmission? Thanks.
Old May 11, 2014 | 04:42 PM
3.2TLc's Avatar
Welcome Gooduser !!!
The P1676 code is usually associated with the ABS/TCS. Maybe a faulty component, loose wiring connection or ground in the ABS system.
The P1750 code indicates a potential mechanical problem within the tranny's hydraulic system. Most times the "D5" indicator lamp will also flash. Try cleaning the pressure control solenoids for the tranny. How's the AT fluid's level and condition appear ?
If ya get a second opinion at a private tranny shop and they also diagnose the tranny as bad, consider installing a used "AV6" donor tranny from an '06>'07 Accord V6. Others have found this to be the best solution rather than a rebuid of the old tranny. The AV6 can be sourced from most auto salvage yards for less than $1000 and then figure another $500 for installation.
Old May 11, 2014 | 07:28 PM
gooduser's Avatar
5th Gear
Thanks! My D5 indicator lamp didn't flash. The AT fluid's level is fine but looks a little dirty. Do maintenance regularly with the dealer and no bad sign for ATfluid reported.
Will check with private repair shop. Should I go to a general auto repair shop or specialized tranny shop?
Old May 12, 2014 | 10:12 AM
skwidstyle2's Avatar
1999 4at
so when installing my motor mounts, i busted (barely like a 1/8th inch crack) one of the plastic plug ins on my clutch pressure control solenoid. it had my d4 flashing & check engine light on & i had no 1st & 2nd gear for a couple days until the part i bought on ebay for $65.00 arrived. knowing what was wrong with it, i just wanted to see what acura dealership would say. of course, they said oh your transmission is gone replacing will be 4k something. my point is just get it properly diagnosed by someone who is honest so you know exactly what is wrong. it may be something very simple. that being said, these trannys do fail so just be prepared to possibly do the accord tranny replacement, but i think it will be a simpler fix.
Old May 12, 2014 | 01:25 PM
3.2TLc's Avatar
Cool Stealership tranny quote......
Originally Posted by gooduser
My car is 2001 TL, 170k, runs perfect until yesterday. My car's engine light and TCS light were on simultaneously when we drive a in parking lot, after a 2~3 mile drive on a bumpy road. After restart the car, TCS light is off. engine light is on again.
Got scared...
If ya don't do your own car repairs, I'd suggest going to a trustworthy local mechanic and explain the situation. A good place to start would be to drain & fill the tranny using Honda DW1 fluid. Check ABS connections. Reset the CEL by removing fuse #13 (7.5A) for the clock back-up. After a minute, put the fuse back in and the CEL should be off. If the CEL comes back on after driving, have the codes read again.
Old May 14, 2014 | 09:52 AM
gooduser's Avatar
5th Gear
Dealer told the same thing to me. Thanks for the kind reply. I think I should find a local mechanics to check this.
Old May 14, 2014 | 09:56 AM
gooduser's Avatar
5th Gear
Thanks again! Will follow the instructions and see what will happen
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
mars
Sep 28, 2015 11:03 AM
