Help with SRS light on
Old May 29, 2004 | 06:00 PM
fred3113's Avatar
well i was tinckering around with the fuse box on the drivers side and i pulled the fuse on the instrument panel to see if it would kill the miles for shits and giggles and i put it back , but when i did i noticed the check engine light came on and the srs light also came on, i managed to turn off the check engine light, but does anyone know how to turn off the srs light?
thanx
Old May 29, 2004 | 09:00 PM
fsttyms1's Avatar
the dealer has to reset that
Old May 31, 2004 | 12:20 PM
Pot80h's Avatar
One morning my SRS light refused to go off in my 2000TL, so I called my dealer. He told me to bring it in ASAP. There was a faulty sensor in the seat belt receiver. I'd take it in pronto, just in case it's more than the light.
Old May 31, 2004 | 01:13 PM
JPTLS03's Avatar
thanx
You must have had the key in the ignition. That will set the SRS. I unpluged my seats a couple of weeks ago to remove them for vacuuming. I forgot to take the key out because I was listening to the radio. Once again I set my SRS. As fsttyms1 said, the dealer will have to reset it with the PGM.
Old May 31, 2004 | 03:30 PM
Dare_IL's Avatar
Need a WHAmbulance
Here are the instrustions for resetting the SRS light.
1. two wires green in a yellow block (small)
2. under dash left of steering wheel as the driver sits.
3. smaller yellow block is the right one and is located one inch above another bigger yellow wire block which has a spring loaded connector.
Jump it with the paper clip, turn the car on, wait for the SRS light to go off, yank the paperclip out. It'll light up again, shove the paperclip back in...then it'll turn off. Yank it out. It'll then blink twice to tell you it's reset.
Don't worry about the timings...just do it as soon as you see the light change (and do it quick).
I cut a thin paperclip to about 2cm long, then bent it with needle nosed pliars so it looked like a staple. Then I just used the needle nosed pliars to push it in and out of the plug. Just be careful to shove it into the right side of the plug...the one side of the hole doesn't contact the metal.
Old Jun 1, 2004 | 04:02 PM
JPTLS03's Avatar
Don't woory fred, this method does work. A friend of mine did it for me the first time I set mine off. I didn't really pay attentioon to what he was doing but I do know he used a paper clip.
Good advice
Old Jul 7, 2004 | 10:50 PM
hrichny's Avatar
this works great just did it. it took 2 seconds and saved god knows how much dough. thanks alot nice post!!!!!!!!!!!!!!!!!
Old Jul 8, 2004 | 12:31 AM
tumas's Avatar
wow mine has been on for over a year, thanks! i tried it for 30 minutes by myself and i could never get it to work, but when i called my neighbor to help, i got it on the second try, THANKS AGAIN! WOOT WOOT
Old Jul 8, 2004 | 03:15 PM
kaih's Avatar
I followed the procedure but it's not working. I put the paper clip in and turned on the car the light went off. I pulled the paper clip out and light came on. I shoved the paper clip back in and the light never turned off again. I tried several times always same results. I pulled the paper clip out fast and slow always same results. Is there something else wrong?
Old Jul 8, 2004 | 05:39 PM
SpamNEggz's Avatar
6th Gear
...and do the hokey pokey and turn yourself around. wooo wooo the hokey pokey....wooo... the pokey hokey...ooooo
Old Jul 29, 2004 | 01:49 PM
abocic's Avatar
im gonna try this tonite....hope it works........dealer will charge me $75 big ONES
Old Jul 30, 2004 | 11:31 PM
abocic's Avatar
It Works!!!!!!!!!!!!!!!!
Old Sep 7, 2004 | 11:00 AM
Where do you access this plug? Behind the knee panel? How do you get to it, do you have to pull down the knee panel?
Old Sep 10, 2004 | 08:58 AM
heehaaw's Avatar
Did You Seriously Think You Could Reset Your Odometer By Pulling A Fuse?!?!
Holy Crap That Is The Stupidest Thing I Have Ever Heard In My Life.
Old Sep 10, 2004 | 09:15 AM
mikelee223's Avatar
I dont think they are resetting the Odometer. Read the Thread Title. Its to reset SRS. Not Odometer.
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
mugen_kid
Nov 13, 2015 10:38 PM
sockr1
Oct 1, 2015 01:31 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
