Help: Replacing Door Bulb
to recover the harness, you should unscrew the screw inside the arm rest then pop open and pry open the bottom portions enough so you can reach in and grab the harness.
and yes, the other lights are the same.
wusty23jd
09-24-2015 11:41 AM
