Help with REmoving front bumper
Old Dec 27, 2005 | 05:52 PM
BraveDemon's Avatar
I'm Down Right Fierce!
Hi all,
So i've decided to finally install my blacked out headlights, but i'm debating on whether I should do it myself or have it put in for me at a shop. I just needed some opinions on how hard it is to remove the front bumper.
Can I do it by myself?
I tried taking the the pins from underneath the bumper out and they wouldn't pop out like the ones under the hood would; should I just drill through them and by replacements? ANd if so where can I buy the replacement pins?
Thanks in advance.
BTW, I have a 2002 TL-S WDP.
Old Dec 27, 2005 | 05:58 PM
dvsxlt247's Avatar
99TL-p 114K
Originally Posted by BraveDemon
Hi all,
Thanks in advance.
HAHA, if im correct, you just might be going through the same bullshit i went through when removing my bumper. Yes, those pins underneath fucken suck. They deff dont come out nice and easy like the ones under the hood do. What you gotta do is take a looooonnnnngggg flat tip screw driver and that will allow you to wedge under it good and give you more slack to pop them out. It sucks to do it, but even though they give you a hard time, the bumper really is easy to take off yourself. Its nothin really. If you dont know all the steps to taking off the bumper let me know. oh and DO NOT DRILL THROUGH THEM. USE THAT METHOD AS A LAST RESORT IF YOU REALLY ARE INCAPABLE OF TAKING THE GROMMETS OUT LIKE YOUR SUPPOSED TO K.
Old Dec 27, 2005 | 06:00 PM
fsttyms1's Avatar
use 2 screw drivers (1 on each side) odds are you will probably break some. they can be found at the dealer or honda dealer
Clearing is something you can do yourself. do you have teh DIY on doing it?
Old Dec 27, 2005 | 06:23 PM
Love my 99's Avatar
Still sluggin' it out
I would STRONGLY recommend doing a search on this topic before you get started. Its been awhile since Ive taken mine off but I'll give you a few pointers that stand out in my mind:
Taking off your bumper is relatively easy if your even just a little mechanically inclined (like me). You dont have to be a mechanic at all. After you take the clips out of the bottom using the 2 screwdriver-method, remember that you have to remove the bolts in each front wheel well near the area where the bumper meets the fender. After removing these bolts, place one hand on the bottom of the bumper on one side, and the other where you removed the above mentioned bolts and give the bumper a good, healthy tug. Dont pull so hard that you bend the bumper in half; once you feel the one side come out a little, do the same on the other side.
Be sure to lay a blanket down in front of the car in case the bumper comes flying off when you start pulling...never know, you might be stronger than you think...
GOOD LUCK!!
Old Dec 27, 2005 | 08:39 PM
TLsu's Avatar
Wallace, LA
http://www.abunchofcars.com/diy_page...ont_bumper.htm
Old Dec 27, 2005 | 09:19 PM
NYZGREATST's Avatar
Sig Rho's Finest
removing the bumper was the biggest excitement i had with my car. why? b.c it came off without any complications
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
leerbgdup
Sep 6, 2015 11:01 PM
Sixers12
ILX
Sep 6, 2015 07:54 PM
robowarrio
Sep 1, 2015 09:25 PM
