Help! One side of rotor hotter than the other
Old 11-13-2008, 10:46 AM
  #41
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
how did you tweak the caliper?
If everyone wants to put in a buck, I will take the time to rewrite the brake/caliper and seafoam diy's...
otherwise I dont have spare free time, so you will have to look thru the threads to learn the procedure
Old 11-13-2008, 01:36 PM
  #42
wham bam thank you ma'am
Rajca's Avatar
Originally Posted by remikinz
yeah the stock tl calipers arent very impressive... I did the breaks a few months ago thinking maybe my brakes were going lol... nope the pads were fine... so this should be a nice change... having my boyfriend pick them up at his shop sooo excited lol thanks for the tips guys!
SS brake lines? any idea how much they run? eh Ill just use google lol thanks thought!!
stainless steel brake lines, the wont expand under pressure which gives u a firmer brake pedal, excelerate and MrHeeltoe sell them for about $110-$120 for the fronts.
Old 11-13-2008, 03:19 PM
  #43
02TL-osh's Avatar
Originally Posted by 01tl4tl
you want the end clips from the bracket- the ones the pad tab ends slide on
and whatever bolts it came with
do NOT use the large v clip in the center of the caliper!!
It does rub on some cars and is not required
Caliper with R goes on driver side! L on passenger side
prefill the calipers with squirt can of new brake fluid to remove as much air as possible.
Will save an hour of frustraton and trapped air bubbles later!
Thanks! I got it. I only need to use the new calipers and the new slide clips in which pads slide in when pressed by the fingers of the caliper. I was wondering what that center V-clip was for. Really couldn't figure out its real function. I will just leave it out then. Thanks again.
Old 11-14-2008, 09:33 PM
  #44
totaledTL's Avatar
Lol- I meant, I tweaked the "V CLIP" or whatever that piece is called, to clear the rotor. No noise since. And those things were on the calipers to begin with so I figured I'd have some pad rattling noises if I didn't use them.
08-15-2019 12:58 PM
HOWELLiNC
3G TL Photograph Gallery
24
10-08-2015 03:15 PM
Lucrativesoldier
09-28-2015 03:47 PM
TL-GIXXER
09-18-2015 10:25 PM
mav888
1G RDX (2007-2012)
09-08-2015 11:49 AM
Quick Reply: Help! One side of rotor hotter than the other
