Help! One side of rotor hotter than the other
Old 10-26-2008, 11:04 AM
02TL-osh's Avatar
I just notice after driving my 02TL that one side (passenger) of front rotor is much hotter than the driver side. It was burning hot while the other was not nearly burning. This is after about 10 min of mild street driving and braking. Anyone has suggestions? (maybe the right side caliper bad?) Thanks!
Old 10-26-2008, 11:21 AM
wham bam thank you ma'am
Rajca's Avatar
the right side might be hotter either bc its seized, OR doing all the braking while the left one is seized, when u brake does the car pull to a side? just get two caliper from a 95 ls legend coupe. duel piston, better braking and make sure u flush they system.
Old 10-26-2008, 11:30 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
yep--check both front sides brake pads- comapre the inner to outer pad wear and the left side to right side of the car - which pads are worn out and which look new?
Then see if its caliper sticking on, or not working fully
Many of gen2 are at a time where its due for calipers, especially if the brake fluid was not changed on a yearly basis--old fluid is bad news for rubber seals
the correct legend calipers- same price as tl parts- 1995 Legend LS-C (coupe)
use the tl pads rotors brackets- just the caliper is different-- and way better stopping
Old 10-26-2008, 12:33 PM
02TL-osh's Avatar
Thanks for the suggestions!
Old 10-26-2008, 12:40 PM
02TL-osh's Avatar
The car did not pull to one side or the other when braking. As 01tl4tl said, either side is seized. I agree. I think it is time to change both calipers. Thanks a bunch!
Old 10-26-2008, 01:42 PM
02TL-osh's Avatar
Thanks, Rajca and 01tl4tl. I just found a pair of calipers for 95 Legend LS coupe at Autozone. They cost about 95 bucks a pair.
Old 10-26-2008, 01:46 PM
Rajca's Avatar
i called a friend at murray for teh calipers and he said $55 for both with core.
Old 10-26-2008, 01:48 PM
Tri State ViP Crew
CAB NY's Avatar
how much better are the 95 calipers and are they a easy fit
Old 10-26-2008, 01:55 PM
Rajca's Avatar
their dual piston, better stoping. same install as if u were replacing the stock calipers, just have to switch them, left caliper goes on the right side and the right caliper goes on the left side, make sure u put brake fluid in the caliper before u start bleeding.
Old 10-26-2008, 02:00 PM
Tri State ViP Crew
CAB NY's Avatar
thanks
Old 10-26-2008, 04:33 PM
01tl4tl's Avatar
the parts store is even happy to get TL caliper back in the deal,
there are more people wanting those, than something for a 1995 car-
score for us!
Old 10-26-2008, 07:41 PM
totaledTL's Avatar
$55 for 2 rebuilt calipers? That's a steal. Is Murray an auto parts chain?- don't have them where I live.
Old 10-26-2008, 07:58 PM
Rajca's Avatar
yup its a auto parts store, and they rebuilt calipers
Old 10-27-2008, 11:18 PM
02TL-osh's Avatar
I have trouble finding 95 Legend LS Coupe front calipers in my local auto store. Will 95 Legend Sedan GS or LS calipers fit 2002 TL? Thanks.
Old 10-28-2008, 03:28 AM
01tl4tl's Avatar
There were different calipers between the models- not all were dual piston- as I suspect those $55 a pair units may be single piston~
for cross referance- raybestos part frc10627 and frc10628
try a name brand store and have no trouble at all finding th eright ones
Old 10-28-2008, 04:44 AM
Rajca's Avatar
their dual piston, saw it with my own eyes.
Old 10-28-2008, 07:12 AM
totaledTL's Avatar
Looked them up through Murray's website- they were higher than $55.
Nobody around here had them, including Napa- had to be ordered.
Old 10-28-2008, 12:07 PM
01tl4tl's Avatar
you wont find tl or legend calipers in stock anywhere- but they are normally just a day or 2 away at the warehouse
there are also different SIZE pistons between the models and years, its only a mm or3 but I went with the one closest together in size
that suits our needs best
Old 10-28-2008, 12:08 PM
01tl4tl's Avatar
if you print out page 3 of the kragen list of calipers for 95 ls-c, and take to store, they will price match
The store list price is higher than 75
Old 10-29-2008, 01:34 PM
Sippy Cup (x2)
snowman81's Avatar
When I look at the calipers on partsamerica.com, it says they are $85.99 ($50 core) for each side, not the pair. Comes out to $72 for the pair after core charge is refunded.
Old 10-29-2008, 01:45 PM
Sippy Cup (x2)
snowman81's Avatar
01tl4tl, which Hawk pads to you recommend. I remember reading it somewhere but I can't remember where I saw it. Thanks.
Old 10-29-2008, 01:50 PM
GoRavens's Avatar
How did you notice the one side was hotter???
Old 10-29-2008, 02:01 PM
Rajca's Avatar
i got hawk performance street pad and they go threw hell when i drive and they are holding up fine.
Old 10-29-2008, 02:19 PM
Received 1,827 Likes on 1,470 Posts
This is the caliper you want:FRC10627; FRC10628
http://www.partsamerica.com/productd...e=5003&PTSet=A
Go here to get 15% off each caliper:
http://www.icetab.com/partsamerica-coupon.html
Shipping is free on orders over $75.00.
Save on state sales tax by getting them online.
Take old calipers back to a local Partsamerica affiliate and get your core credit applied immediately via their electronic chargeback process.
Buy a can of Seafoam with what you saved on the sales tax.
Old 10-29-2008, 05:32 PM
01tl4tl's Avatar
some states collect sales tax on the order- like Ca.
72.99 per caliper is what I paid after core charge was returned
They are even happy to GET the TL calipers in the deal!!
Old 11-01-2008, 05:53 PM
02TL-osh's Avatar
Well, I drove for 10 min and then stoppd the car. I felt the rotors with my fingers (careful it may burn you!) on each side. The driver's side felt warm but the passenger side was burning me!
Not very scientifically but it works. I wish I could hook up a thermo couple to the rotor to measure the actual temperature.
Old 11-01-2008, 08:05 PM
01tl4tl's Avatar
Use a laser pointed, non-contact, infrared thermometer 30$ harbor freight tools
Then you can measure hot things with ease- point and read
On pads, I like RacingBrake ET300 for normal street drivers,
ET500 for more aggresive street drivers,
or the old standby- Hawk HPS
Old 11-03-2008, 06:47 AM
totaledTL's Avatar
Definitely time to flush fluid & replace those calipers. Even though 1 side isn't sticking it's probably been in service as long as the bad one so replace it too.
Old 11-05-2008, 09:12 AM
02TL-osh's Avatar
Yeap, I ordered a paired of 95 legend calipers from PartsAmerica.com ($80 a piece with 15% discount to a final price of about $67). Will replace them this weekend and report the results here. Thanks.
Old 11-05-2008, 09:53 AM
01tl4tl's Avatar
remember- use a small oil squirt can with new brake fluid to prefill the calipers- saves lots of frustration later on bleeding them- just get as much as possible in.
The caliper is the only part you want- take the new bolts and slider tabs (not the big center one-toss it!- just want the new end clips for the pads and the new bolts)
Do not use the legend bracket!!! It only appears to fit... until you find the bolt holes are offset.
On top of each caliper is a big L or R. put the L on passenger (R) side and R on driver side- that puts the bleeders at the top
After install and bleed, do 2 test stops- from 45mph with full effort to engage ABS and shake the brake pedal
Accellerate to 45 and repeat immediatly
If the pedal gets better 2nd time, you had air in the abs controller- rebleed the system and all is well- will likely find air in LF caliper (based on my personal experience)
Bleed order must be follwed!!!!!!-
LF= driver front, then clockwise around the car
LF RF RR LR
Have fun - its really easy job and well worth doing
Old 11-06-2008, 02:20 PM
totaledTL's Avatar
Vacuum bleeder is a useful thing to have for this job & they're not expensive.
Old 11-08-2008, 08:03 PM
pokes717's Avatar
legend coupe caliper
I just did the legend caliper swap last Friday seems like the best way to go vehicle stops like a champ and no more pulsating brakes either.
Old 11-12-2008, 10:02 AM
02TL-osh's Avatar
I just got the shipment of Raybesto's dual piston to go with my 02TL. One of them turned out to be defective (it won't slide easily, looks like someone tightened the nut too much and grease also came out of the boot). That stinks because I can't do the swap until they send me a new one.
So I just need the caliper itself, take the v-shaped clip, and the bolt (to bolt up the bracket to the caliper), right? It didn't come with bolts from bracket to the car.
Thanks for all the instructions.
Old 11-12-2008, 03:53 PM
pokes717's Avatar
Caliper Swap
Use your TL bolts, TL brakes pads, and my same TL clips I only changed the caliper. I kept all the legend parts and put the in my tool box. But I didn't need them. Again my car stops like a champ with no pulsating anymore.
Old 11-12-2008, 04:17 PM
01tl4tl's Avatar
you want the end clips from the bracket- the ones the pad tab ends slide on
and whatever bolts it came with
do NOT use the large v clip in the center of the caliper!!
It does rub on some cars and is not required
Caliper with R goes on driver side! L on passenger side
prefill the calipers with squirt can of new brake fluid to remove as much air as possible.
Will save an hour of frustraton and trapped air bubbles later!
Old 11-12-2008, 04:18 PM
01tl4tl's Avatar
Use TL pads TL rotors TL brake lines TL bracket
ONLY the caliper is changed
Old 11-12-2008, 05:17 PM
remikinz's Avatar
wow Im going to have to pick up a pair of legend calipers! Ive been looking for a cheap way to get better braking thanks guys! lol learn something new here everyday I love this forum
Old 11-12-2008, 08:37 PM
01tl4tl's Avatar
this 150$ mod is amazing- you probably need calipers anyway based on age, and are the same price as TL calipers,
most users wonder why acura didnt put them on the TL in the first place
Upgrade to SS brake lines for even better pedal feel
Old 11-13-2008, 05:50 AM
remikinz's Avatar
yeah the stock tl calipers arent very impressive... I did the breaks a few months ago thinking maybe my brakes were going lol... nope the pads were fine... so this should be a nice change... having my boyfriend pick them up at his shop sooo excited lol thanks for the tips guys!
SS brake lines? any idea how much they run? eh Ill just use google lol thanks thought!!
Old 11-13-2008, 09:17 AM
totaledTL's Avatar
Originally Posted by 01tl4tl
.....do NOT use the large v clip in the center of the caliper!! It does rub on some cars and is not required....
That's the first time I read that part about this swap- I put them on mine & driver's side scraped the circumference of the rotor. Had to remove caliper & tweak it slightly so it would clear.
Quick Reply: Help! One side of rotor hotter than the other
