Help with Navi..GPS dose not work!!!
Hey wasup guys....i removed my Navi DVD, so i can tap into the wires and connect the RGB unit that Dom sold to me...Welll, when i was pulling it out...i forgot to unpluge the GPS wire,,,so it stripped from the clip....i was like shyt...so when i had everything done...i extend the wire with another wire and hooked it back up into the clip so i can plug it back into the DVD...when i did all that...this screen come up saying that i have to wait up to 10 mins so the car can find the GPS signal....after 10 mins...another screen comes up and it says that i have no signal...that i should disconect the battery for 30 mins then try agian... i did that...and still no luck....
do u guys think i might of stripped the wire from within its cover.
Or is the wire some special kind of wire...Like how our TV cable wires are...thing on the outsite and a thing in the middle?...
please need some help ASAP
thanks in Advance
thanks in Advance
Moderator Alumnus
thanks in Advance
thanks in Advance
Boomer SOONER
so u think i should go ahead and order a new antenna?>....the wire isnt sold seperate..its part of the GPS antenna...its like 98 bucks from acuraoemparts.com
naa the trunk was still closed...how do i take out the gps antenna so i can take it to a TV repair shop?...do i need to take out that back seat cover?...i tried to see if i can take it out....couldnt seem to do it...
Boomer SOONER
Originally Posted by ou sig
you need to take off that rear deck cover - the driver side one. It is easy, but you need to take off the back seat (top part) then the sub cover part (with the light) and you will be able to remove the deck cover and it will be right there.
thanks for the replys
mada51589
05-03-2022 08:54 PM
Luis J. Rodriguez
09-12-2015 10:00 PM
ahsm
09-09-2015 08:35 AM
