HELP!! My Headlights aren't working!!!
Old Jan 28, 2005 | 09:59 PM
hangbok's Avatar
hey guys,
Last week my right headlight bulb stopped working. Thinking that the bulb blew, i bought a pair of philips 4300k replacement bulbs. When i switched out the bulbs, the light still wouldn't turn on!!! What can the problem be? I checked the fuse and the wirings, it all checked out okae. Do you think the ballast can be the problem? Did these every happen to anyone? Someone plz help me out, cuz this whole situation just blows.
kevin
Old Jan 29, 2005 | 06:52 AM
tl_badboy96's Avatar
tl_badboy96
my driver side one went out but it started turning blue and ten got dimmer and dimmer and then it finally went out. i call the dealer and they said the bulb blew, but i going to get a new bulb today and see if this is it.
Old Jan 29, 2005 | 10:23 AM
alpswd's Avatar
Originally Posted by hangbok
hey guys,
kevin
most likely its the ballast
Old Jan 30, 2005 | 12:20 PM
optiq's Avatar
its the ballast. i went through this same problem. bought a new bulb and it ended up being a ballast full of water (only 1 side was not working though.)
Old Jan 30, 2005 | 01:41 PM
Mr Hyde's Avatar
Same thing happened to me after I had a catastrophic sudden failure of my silicone seal on my cleared headlights. The water collected at the bottom most portion of the headlight which empties right into the ballast.
I isolated the ballast, and figured out it was not the bulb or igniter by swapping parts between both sides until I figured out what wasnt wokring. Cost me less than $200 to fix.
Old Jan 30, 2005 | 03:32 PM
Comet2404's Avatar
Flyin' and Drivin'
But then again most of us aren't as talented as you are!!!!!
On a more serious note, I do believe its the ballast, although I wouldn't know where to find one. Dealer is too expensive, Ebay is unreliable for that IMHO, so that just leaves me scratching my head. Good luck!!!
Old Feb 9, 2005 | 03:09 PM
hangbok's Avatar
ahh.. do you what brand our ballast are?
TLrascal
Aug 3, 2018 11:00 PM
acurajj
Sep 19, 2015 03:47 PM
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
