Help installing front lip
Old Jul 23, 2002 | 07:39 PM
vojm's Avatar
Hey guys i'm literally installing the kit right now and i'm a little confused. No intructions came w/kit so I'm basically guessing. On the front lip, would you think it is enough just to attach the screws on the sides (4 of them) or should I also bolt on the nine other hex screws that came with the front lip. The FAQ said I needed to use the Hallow washer for the sides, but I haven't and it seems to work ok. Did I make a boo boo? Please advise.
Old Jul 23, 2002 | 07:52 PM
vojm's Avatar
nm figured out the washer thing...but anyone know if the other bolts are required? Right now the kit is hanging from the 4 screws on the side.
Old Jul 23, 2002 | 08:01 PM
StanMan's Avatar
you need them to secure the middle/front section of the lip.
Old Jul 23, 2002 | 09:05 PM
vojm's Avatar
Well I left the job somewhat unfinished because mosquitos were getting annoying. 15 bites so far . Anyways, there are 9 bolts and nuts left. These are suppose to go in on the underside of the kit, but how do you screw the nuts on? Do you drill a hole and stick the bolt out from the inside and then screw on the nut? Hope it makes sense...
Old Jul 23, 2002 | 09:37 PM
rominl's Avatar
yes you have to put the bolts on to secure the middle, otherwise it will rattle like hell and it might fall out / tear the lip apart.
yes you need to drill holes if your car is 02-03.
for me i put the screw in from the bottom, and bolt it from inside
Old Jul 23, 2002 | 09:49 PM
vojm's Avatar
Thank you VERY MUCH! That's all I needed to now
Feb 25, 2020 09:57 AM
HairyMonkey019
Apr 22, 2016 10:50 PM
08 NBP TL
Sep 8, 2015 08:49 PM
leerbgdup
Sep 6, 2015 11:01 PM
Pegon95
Aug 31, 2015 02:18 PM
