HelP! HID FOGS
Old Mar 20, 2009 | 11:50 AM
Leejahd's Avatar
Exclamation HelP! HID FOGS
Im installing my hid fogs but my passenger side does not want to work so i tested both ballast's on the drivers side and they both work but neither of them work on my passenger side. i connected the stock bulbs and they both work. can anyone diagnose the problem?
Old Mar 20, 2009 | 11:54 AM
nayaab88's Avatar
Make sure the connections are secure and make sure you are not clipping em the wrong way, if it doesn't work one way try and flip the clip and hook it the other way.
Old Mar 20, 2009 | 11:58 AM
Leejahd's Avatar
Like i said they both work on one side but they dont work on one i tried switching the connections but nothing.
Old Mar 20, 2009 | 12:10 PM
jjashaa's Avatar
Avant Garde Wheels
plug n play???
if the stock bulbs work.. they should work..
make sure the pins aren't bent or anything.. and connection is correct.. you could've probably connecte it one way on driver side but on pass side a different way..
Old Mar 20, 2009 | 12:14 PM
Leejahd's Avatar
Yes They Are Plug And Play but i can only connect the plugs one way im about to give up cause ive tried everything.
Originally Posted by jjashaa
plug n play???
Old Mar 20, 2009 | 12:15 PM
nayaab88's Avatar
take a pic of your connections on the side thats not working.
Old Mar 20, 2009 | 12:17 PM
jjashaa's Avatar
Avant Garde Wheels
Old Mar 20, 2009 | 12:29 PM
Leejahd's Avatar
Ok Here
Old Mar 20, 2009 | 12:32 PM
jjashaa's Avatar
Avant Garde Wheels
any closer pics? can't see shit.. lol
pics of connections.. and seriously check if those pins are bent or not..
connection of everything
jjashaa's Avatar
Avant Garde Wheels
why is your right side out btw?
Old Mar 20, 2009 | 12:33 PM
jjashaa's Avatar
Avant Garde Wheels
looks brain dead with just left side on...
Old Mar 20, 2009 | 12:35 PM
Leejahd's Avatar
do you have aim? maybe a little quicker responses
Old Mar 20, 2009 | 12:38 PM
nayaab88's Avatar
lol
x2 on closer pics. take like 2 or 3 with everything FULLY connected and a pic of each connection.
jjashaa's Avatar
Avant Garde Wheels
yea. find me.. its closer than you think..
Old Mar 20, 2009 | 12:41 PM
TequiLa's Avatar
(ಠДಠ)
what brand are they? when i got mine from ddm tuning, my friend who worked there told me we needed to do some snipping and rewiring the HID ballast.
Old Mar 20, 2009 | 12:57 PM
03tlCHARCOL's Avatar
WIP-Work in Progress
I had the same problem, where one side would not light up even when I tested the bulbs and both were working. In the HID Kit that I bought, in the box there was an extra wire, that has 2 connectors. Plug one end to the ballast connector and the other end to the bulb end and that should solve your problem. When I SEARCHED the forum, someone had a similar issue, it had something to do with the ballast not being able to draw enough current to power the bulb, but with the extra regulator wire it did the trick. Hope that helps.
Old Mar 20, 2009 | 01:42 PM
FirePR2002's Avatar
bringin lead
you need to reverse the polarity on the passenger side. i had to do this with my hid fogs - ran into the exaact same problems you have. flip the 9006 connector on the passenger side around and plug it in. once you do that, I'll bet you a steak dinner they both work properly.
Old Mar 20, 2009 | 01:44 PM
jjashaa's Avatar
Avant Garde Wheels
^ i told him what to do...
got it to work..
op probably went out somewhere to take pics... haha
Old Mar 20, 2009 | 01:57 PM
tegkid's Avatar
spaz
Old Mar 20, 2009 | 02:33 PM
ZEUS'O3TL's Avatar
Low & Slow w/Dubz On My
same here....i had the same problem and i played with the connections and VIOLA!!!
Old Mar 20, 2009 | 02:43 PM
H-town_Ryda_06's Avatar
TeXas MaDE CusToMz
might need a relay kit if the igniter cant pull enough current through factory wires.. the ddm website has a kit for $25
Old Mar 20, 2009 | 03:44 PM
Leejahd's Avatar
Oh Man Finally Got Everything Together Thanks For The Help jjashaa!
And thanks for all of the replies everyone!
Old Mar 20, 2009 | 04:58 PM
twistedwedge's Avatar
6MT Someday..
so what was the problem? plugged in wrong? I have the same kit you do and it worked like a charm first time..30 minute job.
Glad you got them to work!
Old Mar 20, 2009 | 06:53 PM
tegkid's Avatar
spaz
Old Mar 20, 2009 | 07:13 PM
ZEUS'O3TL's Avatar
^smartass....thats a violin.......lol..
Old Mar 20, 2009 | 07:22 PM
jjashaa's Avatar
Avant Garde Wheels
^ actually... http://images.google.com/images?hl=e...=Search+Images
search that on google...
what you really wanna say is voila
Old Mar 20, 2009 | 07:23 PM
ZEUS'O3TL's Avatar
damnit i knew i had it rite in the first place....
Old Mar 21, 2009 | 12:58 AM
Leejahd's Avatar
yea i had some things connected wrong but jjashaa helped me fix it! but now one fog is higher than the other
Old Mar 21, 2009 | 08:02 AM
FirePR2002's Avatar
bringin lead
aim it down with the adjuster screw.
Jul 16, 2017 07:33 AM
Avenger411
Oct 11, 2015 03:53 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
rhdune16
Sep 28, 2015 11:31 AM
h22lude
Sep 27, 2015 06:22 PM
