help anybody
Team Nighthawk Member
help anybody
my enginge light lite up and i went to auto zone to get it check by the computer and it said i had a egr valve was getting bad or something. where is the egr valve located at? i have a 99 tl
EGR Valve: Insuffient Flow.
YES we all get this. just clean it out and the engine light will be gone. the search feature is also extremely useful. this is a topic that's brought up every single week at least twice.
you dont need a egr valve you need to clean the ports
http://www.acurainspired.com/forums/...showtopic=4003
start off by getting 3 or so cans of SPRAY carb cleaner and acouple small scrub brushes.
if your engine is any thing like the 2nd gen
baisicly you take the plastic engine cover off 4 10-mm bolts. then disconect the battery. they disconect the rubber hose that goes from the air box to the throttle body. continue to unplg any thing that goes to the intake (any plugins hoses) then there are 10 10mm bolts on the top plate (the part that sticks up thru the plastic engine cover) oull that straight up being carefull to not damage teh gasket. then there are like 8 bolts (12mm i think, i cant remember off the top of my head) then you are able to pull the upper part of the intake manifold off (double check before you pull straight up that every thing is disconected) then get your self a nice place to work and start cleaning. (stick a bag over the TB before you hose every thing down like in my pic to be safe)
it sounds like alot but its really easy should take about a hr to do
thanks alot and i did try the search i type in egr valve and it gave me mumbo jumbo
