Help!!!
Help!!!
02 TL TYPE S AUTOMATIC THE SHIFTER WILL NOT SHIFT OUT OF PARK UNLESS I USE THE SHIFT RELEASE THIS PROBLEM CAME OUT OF NOWHERE A WEEK AGO AND IS STILL CAUSING ME TROUBLE
WHAT CAUSES THE SHIFTING TO JAM UP I HAVENT HAD ANY PROBLEMS IN THE PAST WITH SHIFTING IS THERE SOME KIND OF OIL OR SOLVENT TO LOOSEN UP SHIFTER THAT MAYBE NEEDS TO RE-GREASED SO CAN EASILY SHIFT INTO GEAR
I NOW HAVE TO STICK SCISSORS INTO THE SHIFT RELEASE AND PUT THE CAR IN NEUTRAL JUST TO DRIVE DAILY AND SOLUTIONS WOULD BE APPRECIATED THANKS
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
are the brake lights ALL working? The brake light switch failure can cause what you describe. Have someone hold the pedal down while you check - each taillight one and the ones in the center light on rear deck
Any warning lights on?
Under the shifter base are 3 microswitches that operate the system, no cables are used!
If liquid got spilled in the cup holder it leaks right down to the switches and corrodes them--big problems can result
Acura designed the safety lock override to be operated by the ignition key!
Insert and depress lock- put in Nuetral and start car
Please dont use all CAPS- Its considered shouting and is harder to read for some of us, thanks
there is 1 brake light switch at the pedal that operates the lights
Those fail or sometimes are just loose connection
There are 3 electric micro-switches for shifting that can be damaged by spilling soda or water in the cup holder or shifter area
They dont cost too much but its a PITA getting to them
A possible fix if you had a spill is CRC electrical contact cleaner and a long straw (comes with), spray liberally down inside the shifter
The switches are located under a plastic piece so you can't reach them directly- have to let it drip and hope~
yes this has to be what it is no warning lights are on but none of my break lights work i'm shocked that I haven't been stopped by a cop yet a cop even followed me for 5 blocks and just kept goin never stopped this has been goin on for over a week does anybody have a d.i.y step by step for me and what parts do I need exactly I appreciate all the feedback
would everything be link if there was liquid spilled in the cup holder is there some kind of hole in the cup holder and would this problem effect everything causing my shifter to lock up and all the brake lights going out or could it be both things that the connection under the pedal is loose and 3 connectors under the shift pad are corroded and lock my shifting up
Also with the crc electrical cleaner should where exactly should i spray at should I spray in the shift release where you can push a key down to release the shifter anybody in here an acura mechanic and know how hard of a job this is and cost in Pennsylvania?? once again I appreciate everybodies input
First check the brake fuse. If its ok, Just buy a new brake switch. It has nothing to do with any thing spilling in the cup holders. This has happened to many. There is DIY on it and it takes all of 20 min to replace.
That is the reason your stuck in park. The same switch that tells the brakes to come on is the switch that tells the shifter you have applied the brake to allow it to come out of park.
malayalee king or anybody in the d.i.y what did you use to remove the bolt to take off the bad brake switch is there anything you can use besides a 14 or 15mm wrench or exactly what can be used?
What else would you use but the correct size wrench? You may be able to get a crescent wrench on it to remove it.
