help
help
what's up guys i need some help,i have a 02 tl and i want to know to take the orange part out of the headlight someone told me to put it in the oven but i rather hear it from u guys first thanks.
there is a diy on Headlight Clearing that explains the how to
Warm the oven then turn it off or use 200F- use foil to expand the size of the oven so entire unit fits inside warmed area
Have to reseal it perfectly too or leaks water and blows bulbs and ballast $$$$
HUGE RISK of melting the mounting tabs on the housing!!!
Thats replacement of $200 part or some innovative use of JBweld for plastic
Avant Garde Wheels
^ it all depends on how you open it...
if you open it up cleanly without bending anything, then sealing won't be a problem..open it up with no damages on tabs or anything and seal it up with ease..
no need to use extra silicon cuz i've never used extra on alll the headlights i've done...
2 07 TL-S.. M35/45.. 99-01 TL.. and 2 of mine.. never have i have used extra silicon.. just heat up whatever that was there and just seal it tight.
