Help!
Old Nov 15, 2005 | 12:04 PM
PiMpiN wHITe Cl-S's Avatar
Help!
well my car just broke down at work. i dont know if its an electrical problem or either the alternator died, could be numerous things. i first noticed a slight problem on my guages where the needles would just die out and then the check engine light comes on kind of like surge for one second. this happened about 2-3 times in the past week. at first i thought it was the tranny going but this is not the case now. is there a way to see if my alternator is dead? i changed out my battery about less than a year ago so i doubt that is my problem. any help would be appreciated.
Old Nov 15, 2005 | 12:10 PM
fsttyms1's Avatar
does it start?
Old Nov 15, 2005 | 12:20 PM
no start, no power, none of the lights come on if i turn the key 2 clicks.
Old Nov 15, 2005 | 12:23 PM
fsttyms1's Avatar
Wel the battery is dead then. As to why?? did you leave a light on? will it stay running if you get a jump start? You may want to get your alternator tested. it kinda sounds like it may not be putting out what it should be if your new battery is dead already
Old Nov 15, 2005 | 12:30 PM
never left the light on. i still need to find someone to jump my car as we speak. do you know if there is a way to get it test without taking off the alt? im hoping its just the battery. thanks for your quick help buddy!
Old Nov 15, 2005 | 01:11 PM
hmm..weird..it MIGHT have been a loose screw that clamps the connectors on the battery. ill just wait a bit and see if that was the problem.
Old Nov 15, 2005 | 01:40 PM
RickRoush03's Avatar
RickRoush03
autozone i think will be able to tell you along with recharge your battery if its rechargeable.
Old Nov 15, 2005 | 03:01 PM
fsttyms1's Avatar
Alot of places can test it on the car
Old Nov 15, 2005 | 03:15 PM
thanks guys! hopefully the car will make it back home. ill get it checked at autozone or sears where i got the battery.
