HELP!! 2nd Gen TL Throwing codes p0170 &p0171!! HELP
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
Hi,
Before I begin, I want everyone to know how much help acurazine has been with my 2000 TL!! Thanks in advance for looking!
Now, My TL started throwing the code P0170 & P0171 about 3 weeks ago on and off..
So I checked all the Vacuum lines and check the O2 sensor and find the o2 sensor out of range.
I changed the J pipe(flrex was ripped) and the front o2 sensor and I am still getting the p0170 and pending p0171?
I have reset the ECM and still pops back up any suggestions?
I have also ran SeaFoam thru the gas 2 cans w full tanks of 93!
Thanks again
TG
Thanks again
TG
Hey Tgkaotic, when replaciing the Primary O2 sensor.....did ya use an OEM brand sensor ? The originals seem to work more effectively than some of the cheaper aftermarket ones.
As Closetprisoner suggested.....check the fuel pressure. There could possibly be a restriction within the fuel delivery system, causing the P0171 code for the fuel system being too lean.
Hi guys,
I will check the fuel pressure this weekend if the snow does not come and I did use the denso oem o2 sensor.![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
IAT I will see and maybe clean it.
The p0170 is the main code that keeps popping up tho!
any more suggestions?
I have the service manual so I will look up the fuel pressure before I test it and follow the porcudure.
Thanks again,
TG
Thanks again,
TG
Jamus22
06-11-2023 10:08 AM
