Hella Trumpet Horns
Hella Trumpet Horns
I have a set of these that I'll be installing soon, but the instructions are a bit vague that come with the set. Can anyone give me some help who has installed them before ? I am unclear as to the wiring leading from the relay.
I have them also, I threw out the relay that came with them and installed them straight up. Here's how I did mine.
positive on battery wired to positive on motor (+)
from Negative (-) on motor, wire through fire into one side of a momentary switch
from other side of momentary switch to a clean ground anywhere in the car.
I didn't use the switch it came with, I bought a small momentary switch from Radio Shack instead.
If you have a question, post on here, I'll check back in a while
TL Type-S Owner
On a scale of 1 to 10, 5 being the shock sensor install, how hard would you say it is to install these? I want to do it. Can you get them at autozone or do you have to order them?
Thinman - Thanks for the reply, but they're different than what you're thinking of.
mbeebe - I ordered them from www.rallylights.com for 33 shipped.
Originally posted by jkc2121
you gonna put them on your roof?
Originally posted by payyourtoll
Oohh, good idea......I would if I had room. I plan on building a tree fort up there, and the horns just wouldnt look right. Some might say it would be RICE.
