Heated seat question
Old Jan 27, 2009 | 10:17 AM
AlanW's Avatar
2006 NBP TL MT6/ 02TL-S
Can someone boil this down quickly for me..
Heated seats in my 02 TLS:
The butt part (lower part) gets nice and warn, even hot, on HIGH setting, on both seats.
The back part (upper part) does not get warm on either side.
Are there even elements in the upper part?
Nothing at all happens on either side, upper or lower, on LOW setting.
What all is probably wrong? It would seem that a heating element that works on HIGH would also work on LOW, so it probably the switch??
Thanks for any help
Old Jan 27, 2009 | 10:31 AM
01tl4tl's Avatar
the driver seat has elements in the butt and low back sections
Passenger only gets butt heat due to side airbag issues
Correct procedure is warm the seat up on High- there is a temp OVERLIMIT switch will will cut the power if left on high too long, when it cools it will come back on
Use high to heat the seats till they feel hot, then go to LOW
Low has a temp thermostat type device- it will come on and off as needed to keep the seat warm
There is a known problem and fix- most often occurs driver seat where a wallet would put extra pressure.
See the DIY- Seat heat fixed for $3
Old Jan 27, 2009 | 10:43 AM
AlanW's Avatar
Thanks!
I guess the driver's side low back element is out.
I do start out on high, seat gets fcuking hot on high after awhile, I am not aware of it ever turning off on it's own-it keeps getting hot until I can't stand it anymore and turn it to low.
I really can't tell it heats anymore on LOW. After turning it off HIGH, seat just cools down to a normal seat just warmed by body temp.
Think maybe there is problem with the thermostat device?
Old Jan 27, 2009 | 10:50 AM
BlackuraTL's Avatar
Broke college grad
haha what you need the seat heater for anyway? You live in Arkansas
Old Jan 27, 2009 | 11:11 AM
AlanW's Avatar
We get a liitle taste of winter here, only it just lasts 2-3 months
Old Jan 27, 2009 | 11:14 AM
fsttyms1's Avatar
Oh please. They arent even needed up here where is -10F in the am.
Old Jan 27, 2009 | 11:18 AM
01tl4tl's Avatar
need and want are different- ask any car salesman
Stop running it on high so long- max 5 minutes should be roasting your butt- then go to low
Maybe you are hitting the overtemp switch and then cant tell
Leather doesnt warm up to body heat that much- its seat heat
Inside the seat is basically an electric blanket for a bed- wires run thru fabric
Apply current thru those wires and they get hot~
Old Jan 27, 2009 | 11:22 AM
AlanW's Avatar
Yeah, but you get lots of practice-you guys are use to it!
I enjoy my heated seat on 28 degree mornings
Besides, it bugs me to have something on my car that doesn't work right
Old Jan 27, 2009 | 11:40 AM
FirePR2002's Avatar
bringin lead
i'm in atlanta and use the seat warmers RELIGIOUSLY.
Old Jan 27, 2009 | 12:11 PM
tegkid's Avatar
spaz
I never use mine but it would be nice if they worked. I'll probably try that diy once I rip my seats out for reupholstory.
Btw anyone know if I changed parts of the leather for suede or alacantara that the heaters could mess it up?
Old Jan 27, 2009 | 12:35 PM
fsttyms1's Avatar
^ you can change it and they will work fine.
Also you can buy complete aftermarket heated seat elements for under 100 bucks on line (for those that want to replace broken units or give the back seat passengers a lil comfort.
Old Jan 27, 2009 | 12:47 PM
AlanW's Avatar
Doesn't the driver's seat also have a side air bag in it?
And for the life of me, I can't tell any difference between LOW and OFF on the heated seats.
Old Jan 27, 2009 | 12:48 PM
01tl4tl's Avatar
a whole replacement mat beats repair on units with more than 1 break -100 bucks is a deal
Old Jan 27, 2009 | 12:51 PM
fsttyms1's Avatar
Yes they both have airbags, the passneger seat has a small occupant detection sensor in it and a position sensor in it to shut it off if a small person/child is in the seat or they are sitting goofy. Thats not something that should be in the drivers seat (small child or sitting goofy)
Old Jan 27, 2009 | 02:17 PM
totaledTL's Avatar
http://www.heatedseatkits.com/
Old Jan 27, 2009 | 02:19 PM
totaledTL's Avatar
Originally Posted by 01tl4tl
....Passenger only gets butt heat due to side airbag issues...
Except for 99 models, right? Don't they have both elements in passenger seat?
Old Jan 27, 2009 | 03:43 PM
01tl4tl's Avatar
the owner manual for each year will say whats heated or not- and why
I can really only say about my 01
Old Jan 27, 2009 | 08:29 PM
totaledTL's Avatar
Rechecked the diagram I have- it indicates the 99 models have heated passgr. seat back.
rockyboy
Aug 4, 2024 10:35 AM
d.lim
Sep 15, 2015 08:54 PM
datadr
Sep 12, 2015 09:12 PM
truonghthe
Sep 7, 2015 11:17 PM
