Heat - too hot?
Team Anthracite Member
Heat - too hot?
Anyone have problems with their heat being too hot? In my wife's '02 3.2 TL, if we set the heat any higher than 65 degrees - we are cooking! Is there a way to calibrate these things or has it always been this way (I do not drive her car much)
Just curious if I need to get it fixed before warranty goes out.
Thanks.
Thanks.
Originally Posted by TBone2004
Anyone have problems with their heat being too hot? In my wife's '02 3.2 TL, if we set the heat any higher than 65 degrees - we are cooking! Is there a way to calibrate these things or has it always been this way (I do not drive her car much) Just curious if I need to get it fixed before warranty goes out. Thanks.
If I remember info from the Owner's Manual correctly, if you set the temp real low (65 degrees?), the AC runs all the time. Set it real high (can't remember the temp) the heat runs all the time.
Originally Posted by MikePA
Get it fixed. Something's wrong with your automatic climate control.
I also live in NJ, and i usually have to set it to around 68-69. I usually put it to 75 first though, so it will warm the cabin a little faster. After that I have to turn it down below 70 otherwise it gets too hot.
what the.. mine is nice and cozy just at 72... and it gets to that temp pretty fast when i leave it on full auto. i love the auto climate feature, leave it on a prefered temp, pop the other knob into full auto mode, and just drive around.
my is alittle weird also I ahve a 02 TL-s if. I seem it it has a hard time rugulating heat.. Usally in the moring I will set it at about 75, then i have to durn it down to about 68 to keep a good temp... Defently doesn't work as well as my wifes Yuk
I have mine full blast at 90 degrees in the winter and I'm normally wearing a coat and sweater. I must have climate control problems of my own....
Seriously though, about your TL, I think you might have a potential problem and should get it looked at.
