Hearing noise twice after engine started
I have a 2003 acura tl-s, I can always hear some noise TWICE somewhere under the hood in front of driver's side. It sounds like motor moving, each lasts about 0.3 seconds.
This only happens when the I first start the engine and drive the car from a dead stop.
It's still under warranty, should I go to the dealer and have my car checked?
Will they charge me any fees for inspection?
Any ideas?
Thanks.
Any ideas?
Thanks.
I hear the same noise. It only happens when I first drive it after being parked for a while. The first noise is when I first drive forward and the second noise is maybe like 5 or 10 seconds after that. Then nothing. I figured it was the ABS but not sure that I should have it looked at.
there absolutely nothing wrong with your car. the noise you hear is from the abs sensor going to work. you will hear 2 small noises when you first turn your car on to drive. as i recall, it happens under 10mph.
Mike Bertram
Sep 10, 2015 09:27 AM
