Headlights?
Old Nov 24, 2014 | 09:16 PM
pchat93's Avatar
Headlights?
Hey guys,
New to acurazine. I have a 2001 acura tl. I think it's time I change the headlight bulbs because of the pinkish white-ish color. I wanted to ask which bulbs would be the best fit. Also which is better, 4300K which is OEM color or 5000K? I know the acura dealer is gonna charge about 400 to change them reading all the other posts on it. Let me know your opinions.
Old Nov 24, 2014 | 09:35 PM
thisaznboi88's Avatar
4300k is the best. 5000k is okay if you want some color, but I would not go any higher than that. But your bulbs at theretrofitsource.com. Its way way cheaper
Old Nov 25, 2014 | 07:28 AM
3.2TLc's Avatar
Welcome Pchat93 !!!
Don't pay the dealership big bucks. The HID bulbs are available at auto parts stores or online for less than $100/pair. If the only problem is a worn out bulb, it's an easy "DIY". Check the 2nd Gen's "DIY" sticky for info.
Should there be moisture damage present in the OEM components, then go with an aftermarket HID replacement kit. $100 for the kit, then either DIY install or pay a shop about $100 for labor installing the new kit.
Old Nov 25, 2014 | 10:27 AM
01tl4tl's Avatar
yes pink is age death
and yes at our cars age and the improvement in modern technology- its worth it to replace the entire system for 60-100 bucks from good sellers, note OE bulbs go for 150 each!!
the problem with some aftermarket bulbs is the resistance they run on doesn't match the OE ballast output = bulbs don't work,, or they die young
That's another good reason to update the lighting system, because we have HID its simply cut and install new connectors to new parts- done
35 watt is stock ballast and 5000k bulb color to best see objects on the road
try HID Kits | Conversion Kits | Xenon Headlights | HIDeXtra or the retrofitsource, mention acurazine for best discounts
iirc hidextra has a massive December sale!!
are you getting any moisture in the headlight lens after rain or car wash?
Old Nov 25, 2014 | 10:29 AM
binary_10essee's Avatar
Originally Posted by 3.2TLc
Welcome Pchat93 !!!
Less than $100/pair in auto parts stores? Are you sure? When I originally started searching for HID replacement, the bulbs for mine were $100 EACH in local auto parts stores (AutoZone, O'reilly and Advance Auto). Weird.
But yeah, it's not a difficult project. Check the DIY as suggested. And if it is just the bulbs, that's even simpler than replacing the ballasts and all. I can also vouch for the $100 or so for labor at a shop, because I was originally going to allow a shop to replace mine. Ended up doing it myself with a second set of hands from a friend. Took all of 30 minutes, start to finish.
Old Nov 25, 2014 | 09:25 PM
01tl4tl's Avatar
Doh' computer ate my reply- so the mercifully short version is:
Buy the kit now- contains 2 of everything for less than you are pricing bulbs for
Install the new bulbs- do both or color and brightness will be way different
Then when the ballast and invertor/igniter do the flick the switch dance = you have the needed parts ready to install!
Old Dec 2, 2014 | 09:43 PM
pchat93's Avatar
Thanks for the replies guys. I got 2 new 4300K phillips bulbs. . I'm going to a shop to put them in.
Old Dec 3, 2014 | 10:54 AM
01tl4tl's Avatar
how bad was the reaming for them to install bulbs?
let us know when you get the infamous one side wont light or quits while driving
or that problem alternates sides- and the only way to get light back on is flick the switch a few times! that's great fun at night on the freeway
then ask us again about why the kits were the way to go
Old Dec 3, 2014 | 11:49 AM
rsj0714's Avatar
5th Gear
Great site, thanks
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
