Headlight problem
Old Sep 25, 2001 | 11:26 PM
Headlight problem
Finally got this forum back up, jeez.
Well anyway, I finally got my tl lowered and put some sways on it, and now need help on fixin the headlights. You see, they kinda point down too much. Does anyone know to adjust the headlights on the '02 TLs, cause if you do i need help before i run into somthing.
Thanx
Old Sep 26, 2001 | 12:20 AM
GOT PSI?'s Avatar
It's Go-Time.
I would just take to your local Acura dealer and let them re-align the headlights. I had my dealer re-align the beams while I was getting my first oil change at the same time. My dealer charged me $20.
Old Sep 26, 2001 | 01:42 PM
oracion's Avatar
Yeah. The dealer should be able to fix that pretty easily. Just schedule an appointment.
Old Sep 26, 2001 | 02:34 PM
Do a search, someone just posted the instructions with good pictures not long ago.
I need to have mine adjusted too, I'll probably have the dealer do it.
Old Sep 26, 2001 | 02:38 PM
thephantom's Avatar
It is very easy, jjust do it yourself.
Old Sep 26, 2001 | 02:47 PM
When I read the instructions it did look very easy, the only thing that I didn't get was at point to aim your headlights. By that I mean the instructions said pick a spot on the wall, mark it and then adjust ..... However, that has to be a way to determine how high the mark should be at X feet from the wall. If I knew this piece I would do it myself.
Old Sep 26, 2001 | 03:08 PM
thephantom's Avatar
Use another car and turn the lights on and mark the spot. Then pull your car up to the same spot and turn the lights on and adjust.
Old Sep 26, 2001 | 03:39 PM
Ex TL-S owner
Damn! Thats too much money for something that takes a min. All you need to do is locate a nut w/teeth around it. It's right behind the headlights. After you located it, take a 10mm socket and turn it left or right. Find a level driveway and aim it at something. Hope this helps.
-Ben-
Old Sep 26, 2001 | 07:01 PM
tdoh's Avatar
Make sure the other car isn't lowered, too, if you're gonna go that route!!!
Tony
Old Sep 27, 2001 | 09:30 AM
Road Rage's Avatar
Not a Blowhole
The warranty covers routine adjustments during the 2st 12 months, right?
My dealer did it for free with no questions asked.
tman570
Jun 11, 2019 07:56 AM
TLrascal
Aug 3, 2018 11:00 PM
MistaWet
Sep 15, 2015 08:26 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
